Thread: Won't start after cam install
Results 1 to 20 of 448
  1. #1 Re: Won't start after cam install
    GT Level Member RegalGS98s's Avatar
    NJ
    Quote Originally Posted by Bedwards View Post
    Got the plugs changed. Running smooth at idle now! AFR stays between 14.9-15.5. RPM stays constant. Boost gauge doesn't jump around anymore. Yay. I was gonna change the axle tonight but I dont have a 36 mm socket, only a 34 mm for the new one. Boo.
    Should be a 35mm socket, not 36mm. I know I preach this place alot, but here's the set I have 7 Piece 1/2" Drive Front Wheel Drive Axle Lock-Nut Socket Set Catch it on sale and use a 20% off coupon. Works out costing about the same as 2 sockets from autozone. This is one of their items made in Taiwan, not China so it's the good stuff.
    SMGPFC #0330 - 3.25, Intercooled, Custom Tune, 1.84rr, LS6 Springs, roller timing chain, SLP Headers, Borla Exhaust, built Trans, B&M Trans Cooler, home cut poly uppers, gapless rings, N* TB, Ported heads.
    Soontocome: CAM?, Custom modified M112, home poured Poly Engine and Trans mounts
  2. #2 Re: Won't start after cam install
    GTP Level Member Bedwards's Avatar
    Calgary, Alberta, Canada
    Quote Originally Posted by RegalGS98s View Post
    Should be a 35mm socket, unless they changed it in the last 2 years. I know I preach this place alot, but here's the set I have 7 Piece 1/2" Drive Front Wheel Drive Axle Lock-Nut Socket Set Catch it on sale and use a 20% off coupon. Works out costing about the same as 2 sockets from autozone. This is one of their items made in Taiwan, not China so it's the good stuff.
    Not bad.
  3. #3 Re: Won't start after cam install
    The car runs and more importantly, drives! I have an exhaust leak and a metallic noise as if something is rubbing on my rotor or something. But I can get those figured out soon. I'm so glad I'm done this sh*t.
  4. #4 Re: Won't start after cam install
    you think its safe to ask for a vid yet? or will "Murphy" show up again?
  1. how hard is it to install an alarm with remote start
    By nascartech in forum Audio, Security & Visual Electronics
    Last Post: 11-01-2010, 05:55 PM
  2. gen v install help
    By aligater in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-08-2009, 02:45 PM
  3. Need Help On Troubleshooting Bulldog Security Remote Start Install
    By eb97951 in forum General Tech Discussion
    Last Post: 12-24-2008, 07:39 AM
  4. Remote Start Install Questions...
    By Incomudrox in forum Audio, Security & Visual Electronics
    Last Post: 12-02-2008, 02:19 PM
  5. car rattles after cam install then wont start at all!
    By chrisb in forum General Tech Discussion
    Last Post: 07-11-2008, 10:54 AM
