Thread: Won't start after cam install
Results 1 to 20 of 448
  1. #1 Re: Won't start after cam install
    GT Level Member shawnschuldt's Avatar
    Jun 2010
    Beloit, WI
    probably a noob suggestion but could having 1.9 rockers or something of that sort with the new cam cause this?
    --00 Red GTP--
    CAR:E85--3.25"--SSAC Headers--ported gen 3--1.9 Rockers--AL 104's--65# Injectors--Zez wet kit 55 shot--9" AEM Cone--HP Tuned by me--No Cat--AEM
    13.07@108mph
  2. #2 Re: Won't start after cam install
    Nov 2010
    Atlanta Ga
    Didnt think about that, I dont know enough about aftermarket rockers to comment on that one!
  3. #3 Re: Won't start after cam install
    GTP Level Member Bedwards's Avatar
    Calgary, Alberta, Canada
    If the cam got f*cked, wouldn't the lifters look like hell too? The rollers on them look brand new. I'll pull the heads tonight and have a look. I REEEEAAALLLY don't want to have to pull the cam out again.
    P.S. I never changed the rockers. They are stock.
  4. #4 Re: Won't start after cam install
    i'd spin the engine so cly 1 is tdc and see where the cam lobes are, im pretty sure they should both be in the closed position., if you drop back in 2 lifters for cly 1, you should be able to tell where the lobes of the cam are.
    any way you look at it something is way off some how some where. i've never seen every push rod bent or broken.
    it would be a trip if you got a boat engine cam shipped to you, most boat engines run backwards.
  5. #5 Re: Won't start after cam install
    Yea I'll try that procedure with the lifters. I bought this cam off 03impala9c1. He's a very well respected member on many forums.
  1. how hard is it to install an alarm with remote start
    By nascartech in forum Audio, Security & Visual Electronics
    Last Post: 11-01-2010, 05:55 PM
  2. gen v install help
    By aligater in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-08-2009, 02:45 PM
  3. Need Help On Troubleshooting Bulldog Security Remote Start Install
    By eb97951 in forum General Tech Discussion
    Last Post: 12-24-2008, 07:39 AM
  4. Remote Start Install Questions...
    By Incomudrox in forum Audio, Security & Visual Electronics
    Last Post: 12-02-2008, 02:19 PM
  5. car rattles after cam install then wont start at all!
    By chrisb in forum General Tech Discussion
    Last Post: 07-11-2008, 10:54 AM
