Thread: Won't start after cam install
Results 1 to 20 of 448
  1. #1 Re: Won't start after cam install
    Our valves aren't adjustable. If you overtorque the rocker bolts, the only issue you might have is a broken bolt.
    Lifters would clack and then fill up in 3-5 minutes of running. I've used lots of Jy motors that sat around in various applications and they are dry too.
    While it's possible that the lifters etc may have done it.. I would think it's highly unlilely.
  2. #2 Re: Won't start after cam install
    GTP Level Member Bedwards's Avatar
    Calgary, Alberta, Canada
    So should I pull the heads? Or just assemble the valve train and try turn it over by hand?
  1. how hard is it to install an alarm with remote start
    By nascartech in forum Audio, Security & Visual Electronics
    Last Post: 11-01-2010, 05:55 PM
  2. gen v install help
    By aligater in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-08-2009, 02:45 PM
  3. Need Help On Troubleshooting Bulldog Security Remote Start Install
    By eb97951 in forum General Tech Discussion
    Last Post: 12-24-2008, 07:39 AM
  4. Remote Start Install Questions...
    By Incomudrox in forum Audio, Security & Visual Electronics
    Last Post: 12-02-2008, 02:19 PM
  5. car rattles after cam install then wont start at all!
    By chrisb in forum General Tech Discussion
    Last Post: 07-11-2008, 10:54 AM
