Thread: Won't start after cam install
Results 1 to 20 of 448
  1. #1 Re: Won't start after cam install
  2. #2 Re: Won't start after cam install
    Ahhhh it looks like the theory about the HB was right. Glad it's such a simple fix. I also have a spare key or two laying around.
    In the assembly of every cam/timing gear job I do, there's a couple things that are constants.
    #1. A picture of the dots lining up. If those dots are lined up, your timing is correct.
    #2. Always put the balancer on as mentioned by Gr8Racing said. That's the way it's done. Although I don't RTV, lube the bolt. I may start though. It's a good point.
  3. #3 Re: Won't start after cam install
    Delaware, OH
    Yeah RTV or loctite is a great thing especially with LS1's. The crank doesn't have a key like the 3800's so they have a bad habit of spinning the bolt and balancer right off the car.
    No More GTP for me.
    2014 Chevy Cruze ECO Manual. 40+MPG
  4. #4 Re: Won't start after cam install
    GTP Level Member Bedwards's Avatar
    Calgary, Alberta, Canada
    I'll buy the balancer today. I hope it fixes it!!!
  5. #5 Re: Won't start after cam install
    I'd say you have a good chance. The motor is moving better with the balancer off. The balancer looks like a second keyway was attempted to be made into it. Very likely the timing of the spark was off which caused the occasional backfire and no start.
  6. #6 Re: Won't start after cam install
    GT Level Member t24moore's Avatar
    Feb 2008
    Houston
    ^What he said.
    We had that problem with a guys car and it drove us batty for 6 months litterally until finally someone suggested looking at the balancer. Sure enough, it was driven on with the key and slot not lined up.
    Comp Turbo 6765 T4-ST5-A2A IC-Ported Heads-Custom Turbo headers-80 lb inj-F-Body UIM and LIM-AEM WB, TEP trans w 1" chain and Circle D TC, Dual 255s, Bilstien Struts
    WHY IS EVERYONE SO OPPOSED TO DOING A COMPRESSION TEST TO TROUBLESHOOT PROBLEMS?
  7. #7 Re: Won't start after cam install
    How the hell do I get the crank sprocket off?
  8. #8 Re: Won't start after cam install
    Wichita, KS
    Quote Originally Posted by benner View Post
    The RTV isn't to keep the bolt on, and there is no need to use LocTite on the bolt either. The RTV seals the bolt to the balancer. If you do not put RTV on the back side of the bolt, engine oil will seep out from behind the bolt, and with the balancer spinning, will fling it. Its not a lot, but enough to make a small mess of things. Thats why the bolt shaft is always wet with engine oil when you first remove it. AND why there is some orange RTV on the back side of it from GM.
    I use te Permetex Ultra Gray RTV for dam near everything on these engines where RTV is need or added. Only other RTV I use is the copper RTV for the header exhaust doughnuts, but thats for obvious reasons because of the temp.
    I have reused my balancer bolt, shoot...probably 2 dozen times. Not kidding here. Its over built for what it is. Ya, its a TTY bolt, but its only been degree once in its life, from the get go by GM. Since then...its reached its torque but never "stretched" again. Same with the flex plate, and torque converter bolts, reused mine countless times I have had things apart, and back together.
    I will loctite my flax plate bolts to the crank hands down. I don't recall if I do to the flex plate to torque converter. I think I may just put some anti seize on them. Never had them come loose on me.
    Good luck, and glad we all got it figured out for you.
    ~F~
  1. how hard is it to install an alarm with remote start
    By nascartech in forum Audio, Security & Visual Electronics
    Last Post: 11-01-2010, 05:55 PM
  2. gen v install help
    By aligater in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-08-2009, 02:45 PM
  3. Need Help On Troubleshooting Bulldog Security Remote Start Install
    By eb97951 in forum General Tech Discussion
    Last Post: 12-24-2008, 07:39 AM
  4. Remote Start Install Questions...
    By Incomudrox in forum Audio, Security & Visual Electronics
    Last Post: 12-02-2008, 02:19 PM
  5. car rattles after cam install then wont start at all!
    By chrisb in forum General Tech Discussion
    Last Post: 07-11-2008, 10:54 AM
