Thread: 1999 GTP help...stalling, lurching, won't start intermittently
Results 1 to 5 of 5
  1. #1 1999 GTP help...stalling, lurching, won't start intermittently
    May 2011
    Canada
    Hi guys. New here.
    The wife has a 99 GTP and it will sometimes just stall. Sometimes it won't start....it will turn over just fine but not fire up. She also mentioned a "lurching forward". I am assuming it is all the same problem....hoping rather.
    I am also hoping this is a "common" issue and has been discussed and diagnosed here before. Any help is greatly appreciated as I would like to buy parts and fix it tonight if possible.
  2. #2 Re: 1999 GTP help...stalling, lurching, won't start intermittently
    First things first...any check engine lights? If so...try and get the codes off of it...that'll help A TON.
    Secondly, Unplug the MAF on the top of the throttle body, then start it. Sometimes they'll turn over and even start for a second or two if the MAF is toast...then it'll "buck", or "lurch"...then die.
    Thirdly, have the ICM checked if all it is doing is cranking over (Ignition Control Module)...it is what the coil packs bolt to. Any auto parts store should test it for free...the last couple things I suggest is if you can get it running long enough check for a massive vacuum leak around all the rubber "T" fittings around the fuel rail/supercharger/lower intake manifold.
    Hope that helps.
  3. #3 Re: 1999 GTP help...stalling, lurching, won't start intermittently
    May 2011
    Canada
    Hope that helps.
    It runs fine for the most part. This is intermittent. Here is what I did like 30 minutes ago.
    So, I swapped out the MAF (was a remanned one if that matters). Everything was working fine. Took it for a test drive and from a slow speed, I floored it and it died. Made some strange clicking noise as it tried to keep idle. Started it, died. Started it, died. Started it and gave it gas to keep it alive and it was choking...perhaps starving of fuel?...don;t know. Died. Started it up and it ran perfectly.
    Does the computer have to re-learn when a bad part has been replaced?
  4. #4 Re: 1999 GTP help...stalling, lurching, won't start intermittently
    Nope...sounds like a HUGE vacuum leak to me really...get a video of it maybe?
  5. #5 Re: 1999 GTP help...stalling, lurching, won't start intermittently
    May 2011
    Canada
    Wouldn't a vacuum leak be constantly problematic? My issue seems to be intermittent
  1. Still seeking help! 2005 GP intermittently stalling
    By GPSteph in forum General Tech Discussion
    Last Post: 09-02-2010, 07:19 AM
  2. HUD and GPS going out intermittently?
    By Jas0n in forum Audio, Security & Visual Electronics
    Last Post: 07-02-2010, 08:22 PM
  3. Lurching ABS
    By timweidner in forum Brakes/Suspension/Chassis
    Last Post: 07-01-2010, 03:50 PM
  4. 97 GTP - Rough idle, stalling after start?
    By Psyk in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-29-2010, 09:08 PM
  5. 1999 Grand Prix sometimes won't start
    By sabram in forum Canada
    Last Post: 09-13-2009, 07:31 PM
