bluegtp91
First things first...any check engine lights? If so...try and get the codes off of it...that'll help A TON.
Secondly, Unplug the MAF on the top of the throttle body, then start it. Sometimes they'll turn over and even start for a second or two if the MAF is toast...then it'll "buck", or "lurch"...then die.
Thirdly, have the ICM checked if all it is doing is cranking over (Ignition Control Module)...it is what the coil packs bolt to. Any auto parts store should test it for free...the last couple things I suggest is if you can get it running long enough check for a massive vacuum leak around all the rubber "T" fittings around the fuel rail/supercharger/lower intake manifold.
Hope that helps.
