Thread: Changing Flexplate - don't have to drop the tranny ?
Results 1 to 11 of 11
  1. #1 Re: Changing Flexplate - don't have to drop the tranny ?
    GTP Level Member VinnieGTP's Avatar
    Las Cruces, NM
    Quote Originally Posted by TDCRacing View Post
    well yours shouldnt be any different then mine huh? I understand what you are saying and agree. There is not enough room to stick anything in there...thats why you have to turn the flex plate so that the bolt is at the bottom of the opening and it actually sticks out past the opening just enough so that you can get a socket on there. And usually it seems the rear main seals hardly ever go out on these cars....the front main seals...yes...mine had 110000 on it and the front and rear were just fine.
    I think one of you is talking about the torque converter bolts and the other is talking about the flexplate bolts.
  2. #2 Re: Changing Flexplate - don't have to drop the tranny ?
    Oklahoma
    Quote Originally Posted by VinnieGTP View Post
    I wanted to say something along those lines but I was not 100%. The Flex plate bolts are closer to the center of the plate and would be obscured by the torque converter, right?
  3. #3 Re: Changing Flexplate - don't have to drop the tranny ?
    Saraland Alabama
    exactly, the flexplate is what the torque converter bolts on, and is bolted to the crank
  4. #4 Re: Changing Flexplate - don't have to drop the tranny ?
    TDCRacing
    Guest
    I was.
  1. L26 / L36 flexplate interchangeable?
    By agrazela in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-12-2008, 09:17 PM
  2. Doing a pan drop tomorrow any tips?
    By alacran in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-08-2008, 05:48 PM
  3. power drop
    By Toasty in forum General Tech Discussion
    Last Post: 03-18-2008, 07:36 PM
  4. Changing headlights
    By Deezul_AwT in forum Visual/Body Modifications
    Last Post: 02-26-2008, 08:56 PM
  5. L26 Lifters and Flexplate in L67?
    By SyntheticShield in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-17-2008, 12:13 AM
