Quote Originally Posted by archemedes View Post
you need room to get to the bolts, I don't think it will slide far enough to get a wrench in there and see what your doing
they have a flexplate inspection cover on the bottom of the tranny between the engine and the tranny...theres 2 peices to it...both plastic...wrench is fine...you will have to rotate the flexplate so that each time you are taking out a bolt it is twards the bottom of the engine...thats it...takes about 10 or 15 minutes because it goes real slow when grabbing 6 or 7 teeth of the flexplate at a time and turning it so the next bolt can be accesed....to make it go faster you could have someone turn the motor via the crank with a socket...but it was easier this way for me. hope that helps
