Installed the speed daddy headers, used new GM gaskets. Sealed with rtv and torca clamps on all slip joints. Used v-band clamp on down pipe. So i started the car ticked like crazy. The motor was still cold, I put my hand on the rear header closest to the egr valve and i can feel exhaust leaking from there. The egr tube looked like it sealed good. I just hope the rear head to header flange is not warped. I dont know if i should do the egr delete to see if that helps. Has anyone else had any issues with sealing the rear headers with the SDs. Thanks for your help!
