Thread: Help!!! Flywheel won't turn!
Results 1 to 8 of 8
  1. #1 Help!!! Flywheel won't turn!
    GTP Level Member Bedwards's Avatar
    Calgary, Alberta, Canada
    I'm putting my motor back in after doing my cam install and I'm trying to put the torque convertor to flex wheel bolts in, and the flex wheel won't turn with a screwdriver. It moves about half an inch and then it stops and pops back into place. I don't know what's going on.
  2. #2 Re: Help!!! Flywheel won't turn!
    I can turn the torque convertor from the bottom, with ease. It spins freely. But the flywheel itself doesn't want to move.
  3. #3 Re: Help!!! Flywheel won't turn!
    are the plugs in the engine?
  4. #4 Re: Help!!! Flywheel won't turn!
    Yea they are. I should have thought of that. I'll remove them and see what happens! Thanks man!
  5. #5 Re: Help!!! Flywheel won't turn!
    Banned
    CT
    It's tough to get that sucker to turn. Taking the plugs out should help a little.
  6. #6 Re: Help!!! Flywheel won't turn!
    Charles City, IA
    Use the crank bolt.
    SMGPFC Two Nipple General
  7. #7 Re: Help!!! Flywheel won't turn!
    dudes at work, so nothing will be done for a while now haha
  8. #8 Re: Help!!! Flywheel won't turn!
    It's almost like your watching me. Haha
    <3
  1. Dont like to turn left but easy to turn right
    By Randall in forum General Tech Discussion
    Last Post: 02-01-2013, 12:11 PM
  2. Key Won't Turn!
    By Hixc in forum General Tech Discussion
    Last Post: 08-02-2011, 12:31 PM
  3. Engine swap, Starter/flywheel problem
    By awesomefullness in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-20-2011, 07:48 AM
  4. Flywheel position
    By TorqueAutoMotiv in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-07-2009, 09:34 AM
  5. is the flexplate the same thing as the flywheel?
    By 98bdgtp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-19-2009, 12:50 PM
