Thread: nitrous
Results 1 to 20 of 21
  1. #1 nitrous
    Waukesha, WI
    tried searching for a write up, couldnt find one.
    anyone on here have a nitrous setup? i need advice on how to install, looking at the zex "smart" kit.
    if you dont like nitrous, keep your b.s. to yourself
    RayRay
    92 Turbo miata
    71 bagged lemans wagon
    02 lexus is300
  2. #2 Re: nitrous
    Quote Originally Posted by redlinepontiac View Post
    nitrous is for fags
    sorry i had too lol but i personally dont have one on my car but ive installed one before. Do you have a spacific question?
  3. #3 Re: nitrous
    utah
    better plan on the wet kit. change to some n20 friendly plugs. then theres not alot too it. wire your arming switch, use a micro switch to activate the solenoids. (WOT) switch run a line off your fuel rail to the fuel sol, then the one from the bottle goes to the n20 sol. then pic where and how you want to mount your nozzle. makes sure its after the maf. then dont jet it to a tiny shot until you can get it tuned to run something bigger.
  4. #4 Re: nitrous
    Waukesha, WI
    thanks that what i was looking for,
    not a specific question, more where someone mounted their solinoids and ran lines, wires. etc
    RayRay
    92 Turbo miata
    02 lexus is300
  5. #5 Re: nitrous
    GT Level Member RamonGTX's Avatar
    menasha wisconsin
    Only pu$$ies run nitrous!! Ahaha
    Polished Gen V, 3.1 mps, intercooled, S1X cam, northstar tb, and Tim King built trans with 3.29s and all the good stuff
  6. #6 Re: nitrous
    Waukesha, WI
    dont be that way -_-
    RayRay
    92 Turbo miata
    02 lexus is300
  7. #7 Re: nitrous
    menasha wisconsin
    I really wanted to be like vince diesel but that's nitrometh haha
  8. #8 Re: nitrous
    Quote Originally Posted by RamonGTX View Post
    I really wanted to be like VIN diesel but that's nitrometh haha
    fixed... and you cant run nitrometh on a DD for any car for that matter... because nitrometh doesn store well in gas tanks my friend...
  9. #9 Re: nitrous
    umm thats what top fuel dragsters use.
  10. #10 Re: nitrous
    Waukesha, WI
    so shave the heads get 14:1 compression and run my car on nitromethane?
    sounds like a plan
    RayRay
    92 Turbo miata
    02 lexus is300
  11. #11 Re: nitrous
    utah
    Got my solenoids on the diag brace. There's a pic in my thread marked "finally"
  12. #12 Re: nitrous
    Quote Originally Posted by boostedcompg View Post
    the kit he is refering to doesn have "solenoids"...
    is this a dry kit redline?
  13. #13 Re: nitrous
    Waukesha, WI
    it was a jjjjjoke
    and a zex wet kit, which i would spray post MAF but i dont want to run a spacer. hmmm
    RayRay
    92 Turbo miata
    02 lexus is300
  14. #14 Re: nitrous
    utah
    Modify vac tree or tap into blower case
  15. #15 Re: nitrous
    Waukesha, WI
    blower case sounds the better route, i wouldnt trust plastic to hold threads
    RayRay
    92 Turbo miata
    02 lexus is300
  16. #16 Re: nitrous
    stock maf setup?
  17. #17 Re: nitrous
    Waukesha, WI
    ATM..yes
    on a 3.4 set up right now, cam soon. when do i need to go to LT1 maf?
    RayRay
    92 Turbo miata
    02 lexus is300
  18. #18 Re: nitrous
    need to? no...
    better? yes...
    especially for nitrous... that way you dont have to tap the blower and can put the jet in front of the TB if you want... just have more options ya know?
  19. #19 Re: nitrous
    Banned
    Jan 2013
    Colorado
    Any update on that?
  20. #20 Re: nitrous
    Waukesha, WI
    i bought a real car....theres your update
    RayRay
    92 Turbo miata
    02 lexus is300
  1. How much nitrous can be ran?
    By basshead42 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-18-2009, 06:05 PM
  2. Nitrous on my GT
    By gpracing in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-26-2008, 12:01 PM
  3. nitrous/pcm
    By justwhisen in forum General Tech Discussion
    Last Post: 09-01-2008, 06:46 AM
