Thread: lim replacement and gen v swap
Results 1 to 20 of 32
  1. #1 lim replacement and gen v swap
    SE Level Member Adam D's Avatar
    Jan 2013
    grand rapids mi
    So i took apart my LIM today on my gtp with 230k on it i wanna throw in a few things if i can. I was thinking some 1.9 rockers but can i do it on stock springs? How about blocking the silencing ports on the supercharger? Of course i am taking care of maintenence items new plugs wires and lim. Headers? Whats the most bang for my buck? Some help please im new seen.
    I found a gen v supercharger for a managable price so thats tje plan any comments to help would be apreciated
  2. #2 Re: What mods to do during LIM
    You don't have to remove the valve covers to do the lim gasket but if you want to do 1.9's then do it I'm still on stock springs but I would recommend replacing with some 90#'s
    The Boss Iceman6669's Avatar
    Jun 2011
    90# springs are hard on the dampener. If your only wanting to do rockers get and get L76 springs. Port the blower while it's off. Headers will be nice also.
    2011 F-150 Yote powered
    Jan 2013
    grand rapids mi
    Whats the worst case scenario on stock springs? Im tryin to get it goin for a minimum amount of cash. Does anyone sell a lim kit autozone and advance dont even sell the blower gasket. Im definatley doin the headers and straight piping the exhaust since it needs exhaust work anyway with the rockers and ported supercharger can i run a smaller pulley? Will a canned tune pcm be fine?
  5. #5 Re: What mods to do during LIM
    worse case it breaks a spring. I've been fine on mine for about 30ish K miles. It's called the upper plenum gasket. With rockers & headers i'm running a 3.4 on a canned tune.
    Jan 2013
    grand rapids mi
    Its called a upper plenum on a s/c motor? I might just run stock springs then if i got 30k out of this i would be estatic how many miles on yours?
  7. #7 Re: What mods to do during LIM
    Yeah that's what it's called. I have 229k miles on mine
    Jan 2013
    grand rapids mi
    Any idea what kind of power you get with that setup
  9. #9 Re: What mods to do during LIM
    Not enough lol. I've never been to a dyno
  10. #10 Re: What mods to do during LIM
    May 2008
    Schuyler, NE
    Springs are encouraged.
    Let me rephrase what has already been said. You can break a valve spring, which can either bend the valve, or drop it into the chamber where it will get bent and broken up, while doing significant damage to the piston and head. You're lucky if you don't have to replace the motor after this.
  11. #11 Re: What mods to do during LIM
    Nov 2011
    NY
    You decided to tear motor apart without the stuff you need or want to put back in it? Without a plan...? No too smart!
    Worst case scenario is your cheapening out on $25-30 worth of valve sprins will cost you a motor, plain and simple! The fact that you're asking if you need a tune tells another story, but anyway. No you don't... But you'll also be wasting the money you decide to put into the engine via mod's WITHOUT a tune! The tune will only maximize the benefit and whatnot of what you decide to add to the engine, drivetrain, etc.
    My personal opinion is you get what you put into it...
    Cheap/Fast/Reliable
    You can only have two of these three, so pick wisely!
    Lim gasket, valve cover gaskets, coolant elbows, rockers sure, but do seals and retainer while there, port that blower and throttle body yourself, change plugs, wires, oil, tranny fluid and filter, shift kit, go open cone and then tune it... You'll love what ya get!
    But the research you should have done already is too late, now you'll have to order things and wait... To do it right that is. Don't just get everything at local stores, there are better places like Rockauto that can have it to your door in no time. I get from them in 2 days regular shipping.
    Anyways... Good luck!
    Jan 2013
    grand rapids mi
    Quote Originally Posted by coolone View Post
    Cheap/Fast/Reliable
    Adding some stuff was kind of a afterthought. And is subject to what kind of money i have to put into it. I dont think i asked if i needed a tune i was wondering with specified mods if a canned tune would work and to be honest despite it being a 3.8 modding a car with 230000 miles on it probably is not good for reliability anyway. I have a limited amount of time to work on this. So if i have to do a little at a time i gotta take advantage of the time i got i understand taking it apart and waiting to put it back together seems questionable but when i got time i got time. So i use it.
    Jan 2013
    grand rapids mi
    Is rockauto cheaper? Or sell more items for the 3800?
    ... osiris94ej's Avatar
    Sep 2012
    Casper Wyoming
    Quote Originally Posted by Adam D View Post
    Cheaper on some items, they have multiple warehouses. Just a mail order parts store.
    Sent using Tapatalk 2 from my GS3.
    Somethings yea. You really need to go do some price comparing for yourself and figure out the best route.
    04 Comp G.
    Jan 2013
    grand rapids mi
    I fogot to ask this does my 98 only have one coolant elbow?
  17. #17 Re: What mods to do during LIM
    Jun 2011
    98 will have 2 elbows...
  18. #18 Re: What mods to do during LIM
    Jan 2013
    michigan
    Quote Originally Posted by Iceman6669 View Post
    this. there is a upper and a lower on most if not all 3800 engines
    also if you are replacing them spend a little extra money for the aluminum ones
  19. #19 Re: What mods to do during LIM
    Jun 2011
    97s and 96s had the rear one built into the tensioner...
  20. #20 Re: What mods to do during LIM
    98 only has 1
  1. Trade 98 GTP lite mods for GTP with mods
    By Shifty in forum Wanted To Trade
    Last Post: 10-20-2012, 07:52 PM
  2. what mods will get me better mpg
    By SDgrandprixGT in forum General Tech Discussion
    Last Post: 07-28-2012, 04:50 PM
  3. new 04 gtp mods. will this do??
    By szalajka05 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-10-2011, 12:46 PM
  4. Self mods. 15.4 e.t to a 14.1 e.t for less than $200
    By GTP LOVER in forum Introductions/Noob Questions
    Last Post: 02-28-2011, 01:47 AM
