Thread: flex plate and torque converter
Results 1 to 5 of 5
  1. #1 flex plate and torque converter
    Apr 2011
    Port Clinton, Ohio, United States
    is there a difference in the Hd and non Hd flex plate and torque converters? i have an L26 and it has the l26 flexplate and converter on it but i need a comp g trans, theres a long story behind this all, but thats neither here nor there. thank you in advance!
  2. #2 Re: flex plate and torque converter
    Charles City, IA
    Yes they are different bolt patterns, and the L26 torque converter is also a slightly higher stall IIRC.
    SMGPFC Two Nipple General
  3. #3 Re: flex plate and torque converter
    Apr 2011
    So if i have an l26 bottom end with a comp g trans which flexplate and torque converter would i run? and thanks for your info so far!
  4. #4 Re: flex plate and torque converter
    If you have an L26 or L32 motor, the flexes were dual drilled for either converter. You can also use either converter on either transmission as they do fit. Only real differences would be size and stall speed.
  5. #5 Re: flex plate and torque converter
    Apr 2011
    so would it be wrong to use the l26 setup in a comp g trans? any pros or cons??
  1. Symptoms of broken flex plate?
    By fst in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-21-2011, 08:18 PM
  2. Flex plate upgrade
    By rodman in forum Turbo
    Last Post: 12-12-2009, 12:25 AM
  3. flex plate
    By tihosick in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-10-2009, 10:25 AM
