Thread: new motor in now have a couple codes
Results 1 to 12 of 12
  1. #1 new motor in now have a couple codes
    Jul 2010
    massachusetts
    getting a P1350 and O2 sensor codes the O2 I can under stand as there is no sensor downstream. Could I be getting the p1350 because I painted the coil pack bracket where the icm attaches to the bracket. I did a little research and if I correct the plate grounds to the bracket. Thanks in advance
  2. #2 Re: new motor in now have a couple codes
    Not necessarily. In most 97+ there is a dedicated ground in the harness to the ICM and it no longer grounds primarily through the base. What's a 1350?
    And where in Mass?
  3. #3 Re: new motor in now have a couple codes
    Jul 2010
    massachusetts
    bypass line moniter and Im in shrewsbury next town over from worcester not to far from standard and linders and sams
  4. #4 Re: new motor in now have a couple codes
    STop..I'm gonna make ya tell me how many regals are in Sams.. lol
    I took a search on 1350 and if you just tossed the motor in, I'd look to the wiring routing for the crank and cam sensors. make sure no terminals backed out of the ICM/PCM or those two sensors.
  5. #5 Re: new motor in now have a couple codes
    Jul 2010
    massachusetts
    it starts right up no problem, when i let of the throttle there is a slight blip in the rpms. drops a little and stabilizes drops a little stablizes and rpms seem fine after that until i come off the throttle again and it repeats the process other wise seems to be running good
  6. #6 Re: new motor in now have a couple codes
    right, well that's because the ICM isn't giving the right signal to the pcm etc and then the pcm is just taking over control.
  7. #7 Re: new motor in now have a couple codes
    Jul 2010
    massachusetts
    so what ya saying in a P 1350 dtc is a real pain in the ass to track down just my luck
  8. #8 Re: new motor in now have a couple codes
    Jul 2010
    massachusetts
    will any problems be caused driving the car this way. I still gotta get a cat welded in after the speed daddy header install. plus the weather really isnt that cooperative at the moment no garage for me. I would have no problem coming out to see you in conn. do you kno of anyone that can tune a 97 after all the other bugs are ironed out
  9. #9 Re: new motor in now have a couple codes
    Yeah, I have the ability. It shouldn't hurt it as long as you don't beat on it. Likely it's a bad wire/connector/pin.
    I hear you on the weather. I'm west of you and it's not looking like any sun this week.
  10. #10 Re: new motor in now have a couple codes
    Jul 2010
    massachusetts
    Ill double check the connector at the icm and the cam and crank never removed the pcm. I lust hope I can track this down.
  11. #11 Re: new motor in now have a couple codes
    It's likely a pin that was out of alignment and got pushed out.
  12. #12 Re: new motor in now have a couple codes
    Jul 2010
    massachusetts
    thats exactly what is was a pin out of alignment just took care of that all is running mint only code now is 02 but that is expected. gonna get the exhaust addressed this week. Bill when do think would be a good time to meet up if you would like and scan and possibly tune the car.
  1. Couple ?s
    By lilbear6889 in forum Visual/Body Modifications
    Last Post: 04-15-2010, 12:14 AM
  2. couple of questions, couple of issues
    By zero in forum General Tech Discussion
    Last Post: 12-30-2009, 04:48 PM
  3. The motor Mount on the passenger side of the motor.
    By Nuzzget in forum 3.1L V6 (LHO/LG8)
    Last Post: 07-30-2009, 09:27 PM
  4. Need a couple PN's.....
    By Iron Indian in forum Off Topic Discussion
    Last Post: 01-02-2008, 09:55 AM
