Thread: Compressor psi during valve spring replacement
Results 1 to 15 of 15
  1. #1 Re: Compressor psi during valve spring replacement
    Minnesota
    a valve spring tool can be made for $3 worth of steel and 15 minutes of your time. it's a plate with a slot in it, and a hole for the rocker bolt. tighten it down, pull the lock, loosen it up, etc.
    it's easy enough. you don't need an expensive tool to do it right.
    Hmm. I guess you could make one but I doubt you could in 15 minutes. Getting the spacing right and stuff would take a longer. I know it is possible but to be honest I think it would be more work than you think. If you have a band saw, drill and taps and some steel laying around I guess it is possible.
    Edit- I thought you were talking about making the tool I listed above. Yes you could make that bar design but I have used one and getting at the rear springs is a *****. I know it just takes time and can be done but with this tool you can do two springs at a time/one cylinder at a time.
  1. Valve spring air compressor tool
    By GOTIT4CHEAP16 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-22-2011, 09:53 PM
  2. Spring Change Tool for Use with Air Compressor
    By TeeWX in forum General Tech Discussion
    Last Post: 06-20-2010, 09:51 PM
  3. A/C compressor control valve location?
    By PCweber in forum General Tech Discussion
    Last Post: 08-11-2009, 08:25 PM
  4. AC Compressor replacement????
    By 03renegade800 in forum Off Topic Discussion
    Last Post: 06-26-2008, 03:18 AM
  5. Valve Spring replacement...
    By Iron Indian in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-01-2008, 07:30 PM
