Thread: Compressor psi during valve spring replacement
Results 1 to 15 of 15
  1. #1 Compressor psi during valve spring replacement
    GTX Level Member GOTIT4CHEAP16's Avatar
    Bowie, MD
    How much PSI should i use when changing the valve springs?
    Gen V, 3.0, Stage 2 heads, XP Cam, SD Headers, N*, LQ4, ZZP Stage 2 Gen 3 Intercooler, CAI, AL 104's Gapped to .055, #130 Springs, 42.5lb Injectors, ZZP Tune.
  2. #2 Re: Compressor psi during valve spring replacement
    GT Level Member torq455's Avatar
    Dec 2008
    Alabama
    whatever your compressor puts out max.
    2002 GTP: K&N, 3.2 pulley, flipped mounts. ZZP SS headers, 180 stat, NGK TR6's, MSD wires, Reptile ported TB, ported S/C, ported LIM, Intense Stage II heads with larger Manley severe duty SS valves, Yella Terra 1.9 full roller rockers, LS6 springs, Racetronix fuel pump re-wire, Oil pressure "kit", JMB FWI. Mustang dynoed at 240 WHP, 272 WTQ.
  3. #3 Re: Compressor psi during valve spring replacement
  4. #4 Re: Compressor psi during valve spring replacement
    Charles City, IA
    90psi or so.
    SMGPFC Two Nipple General
  5. #5 Re: Compressor psi during valve spring replacement
    Bowie, MD
    Thankxs guys. My rockers are done and boy was they hard to do mainly the springs. Im never doin g it again unless i get a better spring compressor.
  6. #6 Re: Compressor psi during valve spring replacement
    Minnesota
    That's why I ordered one of these:
    MMS New and Improved 3800 Specific Valve Spring Compressor Tool: Milzy Motorsports
    Yes it's expensive but worth it. I figure I will rent it out to people and make some money back.
  7. #7 Re: Compressor psi during valve spring replacement
    Quote Originally Posted by Pure2sin View Post
    i just saw that tool being used on a tv show, made it look easy as can be.
  8. #8 Re: Compressor psi during valve spring replacement
    a valve spring tool can be made for $3 worth of steel and 15 minutes of your time. it's a plate with a slot in it, and a hole for the rocker bolt. tighten it down, pull the lock, loosen it up, etc.
    it's easy enough. you don't need an expensive tool to do it right.
  9. #9 Re: Compressor psi during valve spring replacement
    Minnesota
    Hmm. I guess you could make one but I doubt you could in 15 minutes. Getting the spacing right and stuff would take a longer. I know it is possible but to be honest I think it would be more work than you think. If you have a band saw, drill and taps and some steel laying around I guess it is possible.
    Edit- I thought you were talking about making the tool I listed above. Yes you could make that bar design but I have used one and getting at the rear springs is a *****. I know it just takes time and can be done but with this tool you can do two springs at a time/one cylinder at a time.
  10. #10 Re: Compressor psi during valve spring replacement
    Charles City, IA
    I bought mine from snap on for $25.
  11. #11 Re: Compressor psi during valve spring replacement
    Minnesota
    Quote Originally Posted by TheOtherNick View Post
    3 jaw type or the type like I listed above?
  12. #12 Re: Compressor psi during valve spring replacement
    Charles City, IA
    Bar and slot is the snapon one I have that design works fine. I have used the jaw style also when I had the heads off the car.
  13. #13 Re: Compressor psi during valve spring replacement
    Bowie, MD
    This autozone POS is what i used. FML.
    Now my hands look and feel like crap smh. It was all worth it though because the new found power from the 1.9 rockers are AMAZINGG!!!
    So now that i have L76 springs, i can up my shift points to 6,000 rpm's correct? Whats the highest?
  14. #14 Re: Compressor psi during valve spring replacement
    Banned
    Apr 2011
    wv
    ive got one of those simple ones, worked fine on my 7.6L, i dont see why it would take something overly complicated to do the L67
  15. #15 Re: Compressor psi during valve spring replacement
    Quote Originally Posted by GOTIT4CHEAP16 View Post
    Wimp
  1. Valve spring air compressor tool
    By GOTIT4CHEAP16 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-22-2011, 09:53 PM
  2. Spring Change Tool for Use with Air Compressor
    By TeeWX in forum General Tech Discussion
    Last Post: 06-20-2010, 09:51 PM
  3. A/C compressor control valve location?
    By PCweber in forum General Tech Discussion
    Last Post: 08-11-2009, 08:25 PM
  4. AC Compressor replacement????
    By 03renegade800 in forum Off Topic Discussion
    Last Post: 06-26-2008, 03:18 AM
  5. Valve Spring replacement...
    By Iron Indian in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-01-2008, 07:30 PM
