Thread: petroleum jelly in oil pump
Results 1 to 6 of 6
  1. #1 petroleum jelly in oil pump
    Jacksonville, Fl
    I'm slowly pieces the motor back together. I read somewhere that I should prime the oil pump with petroleum jelly. Is this a typical thing to do?
  2. #2 Re: petroleum jelly in oil pump
    If you take it apart, yes. Otherwise, leave the icm unhooked and crank the motor for a few seconds. Let it rest. Repeat that like 3-5 times. That should prime you too.
  3. #3 Re: petroleum jelly in oil pump
    ^^I do the latter...and it seems to work just fine...that way your not getting questioned by your buddy's why your buying it at WalMart LOL
  4. #4 Re: petroleum jelly in oil pump
    pfft...i just started mine up. prime these. (dont do what i did)
  5. #5 Re: petroleum jelly in oil pump
    Jacksonville, Fl
    Alright cause I already cranked the cover down and started putting accessories on. Don't wanna have to break it all back down
  6. #6 Re: petroleum jelly in oil pump
    Waukesha, WI
    ill throw it out there, the jelly trick is oldschool. priming is better
    RayRay
    92 Turbo miata
    71 bagged lemans wagon
    02 lexus is300
  1. Fuel pump or Fuel Pump Resistor
    By Dragan in forum General Tech Discussion
    Last Post: 01-28-2011, 08:01 AM
  2. Bad oil pump??
    By 2kgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-06-2010, 01:28 PM
  3. Oil Pump ???
    By TurboGTP in forum Turbo
    Last Post: 06-25-2010, 09:40 PM
  4. Air pump.
    By jtrain771 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-19-2010, 03:34 AM
  5. Oil Pump
    By blueguy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-06-2009, 05:43 PM
