So i've installed some headers recently. mods include pcm tune, u-bend delete, resonator delete, catless pipe, 3in FWI. Im stumped on why im boosting low. At low to mid rpm at WOT i boost from 1-3 bars less than full boost. at high rpm i boost full. I have checked for vacuum leaks and have not been lucky. I sprayed carb cleaner around the intake manifold and found no leaks. The thing that gets me is that while running an open header i boost full. Can restriction in my exhaust cause low boost? ( at the Y-pipe it goes back to 2.25", stock mufflers) Or what else can be my problem? I'm also running a little rich from the tune if that is some important info...
