What is the purpose of the fuel pump resistor? Run on resistor at normal driving?
It slows down the fuel pump.
Mostly though..it screws with us and causes the car to run for a couple seconds and die. Piss us off and make us replace it.
Bill where is it at? It made me have to tow my car![]()
same thing happened to me last summer.
........or you could just run it in high speed mode all the time like I do.
I rather fix it lol
only the GTPs have the resistor right?
to each his own.
Running it at high mode all the time will make you go through pumps...it is meant to be a temp fix.
i just did mine yesterday, it really isnt too bad, just take your passenger wheel off, take off all that plastic shield in the fender, you will see a bracket connected to your washer bottle remove that and you will have more than enough room to take it out. To get to the harness to plug the new one in just remove your battery and head light as shown in the pic and its right there can't miss it, it took me about 45 minutes to do, the only tough part about it is the diagnosing that that part was actually bad lol
where did you get the replacement and how much was it?
