Thread: fuel pump resistor
Results 1 to 13 of 13
  1. #1 fuel pump resistor
    Nov 2010
    Atlanta Ga
    What is the purpose of the fuel pump resistor? Run on resistor at normal driving?
  2. #2 Re: fuel pump resistor
    It slows down the fuel pump.
    Mostly though..it screws with us and causes the car to run for a couple seconds and die. Piss us off and make us replace it.
  3. #3 Re: fuel pump resistor
    Akron Ohio
    Bill where is it at? It made me have to tow my car
  4. #4 Re: fuel pump resistor
    Donating Users Joe's Avatar
    Waterloo, IA
    Quote Originally Posted by JoshsGTP View Post
    Its behind the passenger fender up by the battery. If you buy the replacement one you just unhook the current one and drill a hole an screw the new one to the firewall.
    2000 Grand Prix GTP
    e: JTuckGTP@gmail.com
  5. #5 Re: fuel pump resistor
    GT Level Member jdmgtp's Avatar
    MI
    same thing happened to me last summer.
    ........or you could just run it in high speed mode all the time like I do.
    2000 GTP, 3.2 pulley, SD headers, 3" exhaust, modded 1.9's, custom CAI, LS6 maf, ported blower/ TB, HPT, 65 lb injectors, E85 in the summer, LM-1 wideband, 180 stat, autolite 104's, GMHD suspension kit. 13.2@104 on street tires w/o ported s/c
  6. #6 Re: fuel pump resistor
    Akron Ohio
    I rather fix it lol
  7. #7 Re: fuel pump resistor
    Akron Ohio
    only the GTPs have the resistor right?
  8. #8 Re: fuel pump resistor
    MI
    to each his own.
  9. #9 Re: fuel pump resistor
    Running it at high mode all the time will make you go through pumps...it is meant to be a temp fix.
  10. #10 Re: fuel pump resistor
    Well..it's right here from the factory
    Shoulda bent pin 85 on the speed relay.
  11. #11 Re: fuel pump resistor
    MI
    I'd rather change out the pump than deal with that BS.
  12. #12 Re: fuel pump resistor
    Jan 2009
    buffalo
    i just did mine yesterday, it really isnt too bad, just take your passenger wheel off, take off all that plastic shield in the fender, you will see a bracket connected to your washer bottle remove that and you will have more than enough room to take it out. To get to the harness to plug the new one in just remove your battery and head light as shown in the pic and its right there can't miss it, it took me about 45 minutes to do, the only tough part about it is the diagnosing that that part was actually bad lol
    slp cai,3dp no cat.
  13. #13 Re: fuel pump resistor
    MI
    where did you get the replacement and how much was it?
  1. Fuel Pump Resistor By Pass Mod
    By bayareagtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-02-2012, 05:49 AM
  2. fuel pump resistor
    By GTPgurl in forum General Tech Discussion
    Last Post: 01-07-2011, 09:19 AM
  3. Thanks for fuel pump resistor, but with only first gear?
    By BoilerGoldGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-06-2010, 08:55 PM
  4. Fuel Pump Resistor Question
    By guitarguyucf in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-26-2009, 04:49 AM
  5. fuel pump resistor
    By gnjim in forum General Tech Discussion
    Last Post: 03-02-2009, 08:26 AM
