Thread: HELP! Sputter Under Boost (feels like missfire)
Results 1 to 20 of 30
  1. #1 Re: HELP! Sputter Under Boost (feels like missfire)
    Apr 2011
    Baltimore
    And yes the engine has to be running. also you can do it without a scan tool but you might broke the sensor. basically all you have to do is listen to the rpm's but so have someone watch the tach. when you hit the sensor the rpm's will jump if the sensor is functional.
  2. #2 Re: HELP! Sputter Under Boost (feels like missfire)
    GTP Level Member OrangeL67's Avatar
    Nov 2009
    Michigan
    Thanks to everyone for the help. I found the problem a few days ago. My .52 gap on the 103's was too large. I took them to .49 and still had a very slight miss. So I brought them down to .45 and she's running better than ever.
    VS cam build 13.01@107 316whp/ XP build #1 12.78@110 334whp/ XP build #2 12.56@113 347whp
    IS3 Cam build (Ready to put out some serious numbers)
  1. missfire under boost
    By blowngp3 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-06-2012, 04:33 AM
  2. Acceleration sputter
    By X97prixX in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-18-2010, 03:42 PM
  3. gtp start sputter
    By zildjian102 in forum General Tech Discussion
    Last Post: 10-09-2010, 11:08 AM
  4. Car starts to sputter between 2k and 2.5k rpms
    By Whitehispanic in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-30-2010, 11:24 AM
  5. bad sputter new guy
    By DIRTYDEVIL in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-26-2010, 04:15 PM
