97-03 should be on the throttle body, where the air cleaner tube hits the engine, should be 2 cables, new cars are fly by wire, you will need some to push the gas pedal for ya.
edit: i just saw you got a 07, someone needs to hit the gas pedal for you while you are under the hood.
