Thread: Different cooling things?
Results 1 to 12 of 12
  1. #1 Different cooling things?
    Antioch, IL
    I got a 2000 GTP, and got a replacement 2000 GTP motor from ebay. The 2 cooling hoses in the back by the alternator are different....
    This will be the engine that sooner than later will be going into the GTP. Look at where the coolant lines are cut off, they are 90 degrees.
    Uploaded with ImageShack.us
    The engine in the car, the coolant lines are attached straight. Why why and what can I do? This confuses me.
    2009 Challenger SRT8
    Expert at being gay.
  2. #2 Re: Different cooling things?
    Grand Island, Nebraska
    could you just swap the entire core?
  3. #3 Re: Different cooling things?
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    x2 swap over your alt and bracket.
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  4. #4 Re: Different cooling things?
    Antioch, IL
    Hmm didnt know I could do that. Is there anything special to reinstall, or anything I should watch out for?
    Why the different pieces?
  5. #5 Re: Different cooling things?
    I guess someone decided they liked it better that way. Ive never swapped one so i cant give any advice.
  6. #6 Re: Different cooling things?
    Waukesha, WI
    is one a Fbody block?
    RayRay
    92 Turbo miata
    71 bagged lemans wagon
    02 lexus is300
  7. #7 Re: Different cooling things?
    Your new motor came from an H body.
    It's all basically the same though. You shoudl remove the three bolts holding that bracket on, use a $4 set of coolant elbows (Dorman 47065) and put your bracket on that motor.
    Three bolts and you are all set.
  8. #8 Re: Different cooling things?
    SE Level Member NineD9GT's Avatar
    Dec 2008
    PA
    That's what I was gonna say, prob from a Bonneville. Did the reverse swap a while ago. Just got some elbows from autopart store
    99 GP GT L26 bottom end, Intense stage II cam, Ported L67 heads w/ LS6 springs, LS1 valve seals, 42.5# injectors, ported sc/intake, custom LS1 TB and MAF, custom FWI, 3.4 mps, NGK TR6, ZZP wires, 180 stat, etc...
  9. #9 Re: Different cooling things?
    Overall the bracket is different though. Swap the alt bracket and it's all the same motor underneath.
    I swapped up to the bracket he has on his old motor and the newer style alt etc on my bonne. Just welded those tabs onto the elbows and off and running.
  10. #10 Re: Different cooling things?
    Antioch, IL
    Excellent, thanks guys.
  11. #11 Re: Different cooling things?
    Check to ensure the flex is the same. both should have 258mm tc bolt holes. The rear exhaust manifold needs to be changed. That bracket for the alt and maybe the AC bracket if it's on there. And the oil filter adapter. The H body one should curl under the engine to the pan and your subframe is in the way. You need the sticks straight out one. that gasket can be found in the common part number thread.
  12. #12 Re: Different cooling things?
    Antioch, IL
    I was going to take the flex I have now and put it on the other engine, it looks brand new. I hope its not a pita to get off.
    Manifolds not a problem, I have headers coming friday
    2 brackets and oil filter adapter, those I will make sure I do. Hoping to get the engine out tmw. Im kinda slow when I am all by myself, today I took the starter and tc bolts off haha.
  1. 99 cooling fan issue
    By spidyrmen in forum General Tech Discussion
    Last Post: 04-23-2013, 05:04 PM
  2. cooling?
    By jerrysalley in forum General Tech Discussion
    Last Post: 08-18-2010, 11:36 AM
  3. A/C not cooling
    By VolsFan in forum General Tech Discussion
    Last Post: 05-16-2010, 08:54 PM
  4. Cooling Fan control
    By schmuve in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-27-2010, 10:05 AM
  5. Cooling
    By Davisgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-10-2009, 07:30 PM
