Check to ensure the flex is the same. both should have 258mm tc bolt holes. The rear exhaust manifold needs to be changed. That bracket for the alt and maybe the AC bracket if it's on there. And the oil filter adapter. The H body one should curl under the engine to the pan and your subframe is in the way. You need the sticks straight out one. that gasket can be found in the common part number thread.
