Thread: Code P0300 , mutiple random missfires, no fix yet
Page 2 of 2 FirstFirst 12
Results 21 to 35 of 35
  1. #1 Re: Code P0300 , mutiple random missfires, no fix yet
    New Brunswick
    Does yours backfire out the exhaust if you let off the gas right before it shifts into second?
  2. #2 Re: Code P0300 , mutiple random missfires, no fix yet
    GXP Level Member offroadfury6's Avatar
    Aug 2008
    Fayetteville, NC
    nah, no backfiring...
    -Update, I put factory air box on today, and cleaned the butterfly reallll good...Looks as if someone took a dump inside my supercharger ... anyways she doesn't studder at start-up anymore. I can't even tell if it's missing anymore, except the few times she had a hard time cranking. It's running a lot better after cleaning around the butterfly but even after 15mins of disconnecting the neg. on the battery cable, she's still throwing the code.
    soooo still no fix....I'm debating reallll hard on trading her in at the dealership for a Chevy Cruize.
    2011 Honda Civic EX-L - Leather/Sunroof/LOADED!
    2009 Saturn Aura XE - I got shift paddles!!!
    '98 Olds Cutlass - Good, Dependable
    '06 GP GT S/C - Traded it in
  3. #3 Re: Code P0300 , mutiple random missfires, no fix yet
    New Brunswick
    I would have them take a look at it before you trade though, The grand prix in my opinion is a much better car
    I might take a crack at dropping mine off at another dealer with experience for a day to see if they can find anything, if not i'll keep my eyes open fora wrecked gxp at auctions and do a little conversion.
  4. #4 Re: Code P0300 , mutiple random missfires, no fix yet
    GT Level Member RegalGS98s's Avatar
    NJ
    Quote Originally Posted by offroadfury6 View Post
    See my review of the Cruze http://www.grandprixforums.net/opini...uze-42895.html
    SMGPFC #0330 - 3.25, Intercooled, Custom Tune, 1.84rr, LS6 Springs, roller timing chain, SLP Headers, Borla Exhaust, built Trans, B&M Trans Cooler, home cut poly uppers, gapless rings, N* TB, Ported heads.
    Soontocome: CAM?, Custom modified M112, home poured Poly Engine and Trans mounts
  5. #5 Re: Code P0300 , mutiple random missfires, no fix yet
    GT Level Member sic6's Avatar
    san marcos, tx
    You really need to do an injector balance test to rule them out.
  6. #6 Re: Code P0300 , mutiple random missfires, no fix yet
    Aug 2008
    Fayetteville, NC
    Well there really is no place around here who does injector testing...my only options is this: gmpartsdirect.com: Alternate GM Catalog
    which they are fairly cheap if I only needed one but 6 is easily $200
  7. #7 Re: Code P0300 , mutiple random missfires, no fix yet
    New Brunswick
    The dealer should beable to do it, I dont think it takes very long unless they find something and dig deeper.
  8. #8 Re: Code P0300 , mutiple random missfires, no fix yet
    Aug 2008
    Fayetteville, NC
    well I was doing some reseach and I read that most places charge like $30-$40 bucks per injector test and cleaning. well hell for that price I can replace them with brand new ones from GM parts direct...
  9. #9 Re: Code P0300 , mutiple random missfires, no fix yet
    Aug 2008
    Fayetteville, NC
    Just so you guys know, PROBLEM FIXED..!!
    I traded her for a 2011 Honda Civic EX-L
    and will be trading that one for a 2012 Honda Civic EX-L when they arrive
  10. #10 Re: Code P0300 , mutiple random missfires, no fix yet
    Your kidding.
  11. #11 Re: Code P0300 , mutiple random missfires, no fix yet
    Aug 2008
    Fayetteville, NC
    Nope...Had to do it...
    kind of like the little booger...
    I couldn't get it inspected, I'm a college student and gas was Freaking killing me, especially since the GP NEEEEEDDSSS 93 octane..
    The GP will be missed but I think it was time to move on...Hey, atleast the Honda is fully loaded...Except the SI version, but I didn't buy it to race, I bought it to be dependable and great on gas, really...
  12. #12 Re: Code P0300 , mutiple random missfires, no fix yet
    illinois
    My GTP is doing the same thing. I changed all plugs and wires, the map sensor, cleaned the maf sensor checked for vacuum leaks. I think it might have something to do with the whole in my resonator. Would that cause my car to run like crap, idle funky, occasionally die when stopped and hiccup?
  13. #13 Re: Code P0300 , mutiple random missfires, no fix yet
    Banned
    Apr 2011
    wv
    check the valve timing. i dont know if chains can skip teeth, but ive seen TONS of belts skip.
    suzie, your resonator doesnt effect the engine at all. it might set a SES light, but it wont run any different.
  14. #14 Re: Code P0300 , mutiple random missfires, no fix yet
    GT Level Member shawnschuldt's Avatar
    Jun 2010
    Beloit, WI
    for whoever was talking about the backfire mine also does it but its fairly quiet, but my car runs fine however so i dont know what causes that
  15. #15 Re: Code P0300 , mutiple random missfires, no fix yet
    New Brunswick
    Well its been a while since I posted here that my cylinder 4 misfire code came up. along with similiar issues mentioned in this thread
    Today aprox 15,000 km later cylinder number 4 blew....fire out the exhaust and caught the back bumper on fire.
    Have to do a teardown now to see what damage occured. End of the plug is smashed, Guessing busted piston and head gasket.
    Compression test in cylinder 4 shows only 30 psi with all other cylinders in normal spec.
  1. Random Misfiring P0300 Code
    By spcguy88 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-10-2010, 09:44 PM
  2. Check engine code: P0300?
    By CSteen85 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-02-2010, 11:45 AM
  3. Sputtering and P0300 code
    By grngt97 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-27-2010, 02:12 PM
  4. random misfire P0300, many new parts
    By MarkB in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-24-2009, 11:10 PM
  5. Code P0303, and p0300
    By Progas in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-25-2009, 09:08 AM
