Thread: Mileage on LIM gasket
Results 1 to 9 of 9
  1. #1 Mileage on LIM gasket
    I have a 98 gtp and was wondering how long you guys have got out of your lim gasket. Mine has 195,000 miles on it so i figure it has been changed but had moisture in the oil cap about a week after i bought it so i changed the oil to see how it looked. It looks ok but i still have moisture in the cap about every 2 weeks i'll pop it off and wipe it out and there is moisture in there i'm not noticeably loosing any fluid but i can't rule it out. Thanks all
  2. #2 Re: Mileage on LIM gasket
    Charles City, IA
    They last till they leak. Do you do a lot of short trips. IE under 15min.
    SMGPFC Two Nipple General
  3. #3 Re: Mileage on LIM gasket
    The shortest trip i do is about 30 min
  4. #4 Re: Mileage on LIM gasket
    I have seen the plastic ones begin deforming after as little as 15,000 miles. Usually this won't leak/cause an issue. However it's time you toss some aluminum framed gaskets in there and stop having the worry about the inferior plastic gaskets.
  5. #5 Re: Mileage on LIM gasket
    Mercer, Pa
    You get moisture if your PCV is disabled also. I use to get some under cap until I got mine working again.
  6. #6 Re: Mileage on LIM gasket
    GT Level Member GtpKo's Avatar
    Best place on Earth
    Do it. Do it now. I waited until 170k miles before doing mine, and I know they hadnt been done after 102k.
    Two things that kill these motors are failed LIM gaskets and KR.
    And if you haven`t already seen it:
    http://www.grandprixforums.net/video...utes-3112.html
    2002 GT F23 5-speed swapped, SPEC stage 2+ clutch, ZZP Power Logs, E-brake handle swap.
  7. #7 Re: Mileage on LIM gasket
    The odd part is... I've never seen an LIM gasket kill one of these yet. UIM's on the NA's...oh yeah.
  8. #8 Re: Mileage on LIM gasket
    Brewcity, WI
    I did mine at 123K cause I had some time to do it, and glad I did.
    http://i162.photobucket.com/albums/t...0/IMG_0202.jpg
    bill, you talking about the UIM warping around EGR.... or is there something else I need to worry about
    /threadjack
    Self-denied SMGPFC member #1
    SEARCH works!
  9. #9 Re: Mileage on LIM gasket
    I'll probably just change it when i get time for piece of mind
  1. gas mileage ???
    By v8teezr in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-02-2011, 07:13 PM
  2. LIM Gasket, Head Gasket, or bad sensor?
    By GTFiske in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-04-2010, 08:40 PM
  3. bad gas mileage
    By Joe m in forum General Tech Discussion
    Last Post: 02-03-2010, 02:17 PM
  4. Need better gas mileage
    By bayareagtp in forum Off Topic Discussion
    Last Post: 12-02-2008, 12:40 AM
  5. Gas Mileage
    By TCO in forum Off Topic Discussion
    Last Post: 05-07-2008, 11:01 AM
