Thread: please dont tell me this is knock
Page 2 of 2 FirstFirst 12
Results 21 to 28 of 28
  1. #1 Re: please dont tell me this is knock
    Bastard Reptile's Avatar
    Kansas City, MO
    16* is too much, for any car...so there's no pffft to it.
    And there's a huge difference between seeing KR on a scanner, and actually hearing something that sounds like gravel chunking around under the hood.
  2. #2 Re: please dont tell me this is knock
    GT Level Member taman86's Avatar
    Nov 2010
    south east AZ
    i need a scanner but the ol lady is getting mad at me for spending money on the car, even though this is the first pay check in like 2 months that ive spent some money on my car, fvcking whiny ass
    01 T/A WS6-SOLD
    97 grand prix gtp- flowmaster mufflers, short ram intake, SD headers (no cat), EGR delete, 160* stat, solid motor mount, AL 606's, ported TB, new coils,lifetime warranty plug wires
    BoostnBlackGTP>"Wbody's r cheap to do up and fix but break down alot lol"
  3. #3 Re: please dont tell me this is knock
    Nov 2010
    south east AZ
    52psi shouldnt it?
    01 T/A WS6-SOLD
  4. #4 Re: please dont tell me this is knock
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    42 psi idle with vacuum at the regulator. 58ish with no vacuum. Drop it down. You might want to double check the gauge is working correct. Thats a CHit ton of pressure you have. I say the chugging your seeing when in boost is caused by this. Higher pressure=lower IPW's the injectors are opening shorter but over fueling
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  5. #5 Re: please dont tell me this is knock
    GT Level Member DBGP's Avatar
    Vancouver, BC, Canada
    Holy if my gauge is correct then yea no wonder my car is about to die. If its faulty what would be a good idea how to check?
    (sold) 1998 GP GT- ssm90'd. ported blower and lim, zzp fuel logs, l67 inj, 103's, zzp 2.5"dp, magnaflow mufflers, zzp plog, 3.8" ssm90 pulley, eibach springs, short db's
    2002 Z28 LS1- stock for now
    2012 chevy sonic 5spd
  6. #6 Re: please dont tell me this is knock
    Ok i tried lowering my fuel psi. I got it to the mid/upper 60s, anything lower and the car struggles to idle and the rpm's go from 700-1500ish. Or is that normal, ive heard that the ssm90 sometimes does that when its cold, or is the psi gauge faulty and i am at the right psi?
  7. #7 Re: please dont tell me this is knock
    Hagerstown,Md
    Let the car warm up then lower the FP. If it stalls then your gauge is off. SSm90's do indeed surge on a cold start. So do must modded gp's FWIW
  8. #8 Re: please dont tell me this is knock
    Ok thanks. Yea i did notice the idle improving once it was starting to warm up. Il give it another shot tomorow
  1. Listen to the knock knock knock....
    By Lsick7 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-23-2011, 05:40 PM
  2. knock
    By 04BlackComp_G in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-02-2011, 12:27 AM
  3. If if dont make money it dont make cents
    By CrAnK_DaT_SoUjA_BoI in forum Introductions/Noob Questions
    Last Post: 08-18-2009, 01:00 AM
  4. How much knock is ok
    By jacobmh27 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-10-2009, 05:35 AM
  5. Bad EGR = knock?
    By Sabrewings in forum General Tech Discussion
    Last Post: 07-31-2008, 07:13 PM
