Thread: Dual injectors per cylinder?
Page 2 of 2 FirstFirst 12
Results 21 to 27 of 27
  1. #21 Re: Dual injectors per cylinder?
    Odessa, MO
    Here are some pics for you to contemplate. Appears to me to be totally feasible if you remove a small amount of material off of the edge of the LIM in six places around the L67 injector bosses on the heads. Probably would require less material to be removed than it looks in these pics since the LIM would be spaced up a bit more with the gaskets in place. Of course, I'm assuming you are using an N/A intake with a turbo setup as a SC is never going to mate to the N/A LIM.
    The injector holes appear to be angled away from each other enough the injectors would not hit one another, but I don't have any injectors laying around to test that for sure. These pics have the LIM bolt holes lined up with the LIM bolt holes in the heads, so it is sitting right where it would be (minus gaskets) if you were to install it this way.
    Good luck!
  2. #22 Re: Dual injectors per cylinder?
    GTX Level Member 97gtsc's Avatar
    Jul 2008
    Livonia MI.
    Octane on demand!
  3. #23 Re: Dual injectors per cylinder?
    This is awesome. Can't wait to see if anyone actually tries this.
  4. #24 Re: Dual injectors per cylinder?
    GT Level Member tdm571's Avatar
    Lakeside Park, KY
    Quote Originally Posted by slick2500 View Post
    I second this motion!!!!!
  5. #25 Re: Dual injectors per cylinder?
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    you could get a SS m90 LIM from ZZP for a supercharged application as the injector boss's are in the lim
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  6. #26 Re: Dual injectors per cylinder?
    SE Level Member Turbo1dr's Avatar
    New Bern NC
    THANK YOU!
    Looks VERY promising from what I see in the pictures. Since I'll be turbocharging mine, I've already picked up a upper and lower intake manifold from a 99 Firebird. My thoughts were to use that with a L67 long block and whip up a dual fuel system like I already have on my 78 Malibu.
    This is definitely on my "to do" list.
  7. #27 Re: Dual injectors per cylinder?
    nice!
    glad someone took a leap and laid some thing on top of one another finally.
  1. From misfire at cylinder 3 to a open circuit on the fuel injecter at cylinder 5
    By bbfanatic23 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-01-2010, 07:49 PM
  2. Cylinder #1 misfire and random cylinder misfire
    By whodat79 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-21-2010, 07:16 AM
  3. Coding cylinder 3 missfire and cylinder 3 injector port open
    By MATHEWSMAN1969 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-20-2010, 04:27 PM
  4. 5 Cylinder GTP
    By blueguy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-11-2009, 10:42 AM
