Thread: Aeroforce says Misfire...
Results 1 to 17 of 17
  1. #1 Aeroforce says Misfire...
    GTX Level Member tayl5645's Avatar
    Jul 2010
    Michigan
    So Just put the Aeroforce in two days ago.. and the last two days on the drive to and from work Ive been getting random misfires on it. Yesterday I only noticed cylinder 2, but today all of them caught a misfire atleast once. My question how reliable is the Info that comes from the Aeroforce? Can I trust that they actually are misfires?
    It happened when under light load or when backing off the trottle to coast . It has also been freezing here the last two days freezing rain crap. I doubt that has anything to do with it. This was also when the car was fully warmed up.
    I plan on doing Plugs and Wires as the car has 80K on it and idk if its ever been done. Anything else guys?
    2005 GTP Grey
    Custom built Open cone intake, 15% tints all the way around, 7" touchscreen DVD player
  2. #2 Re: Aeroforce says Misfire...
    GT Level Member SlowRR's Avatar
    Brookfield, IL
    Mine always tells me I have a misfire on 4 at idle, sometimes up to 18 before it recycles. I've changed plugs, wires, coil packs, and even the injector. Still has misfire so either aeroforce is wrong or these casrs just have a natural misfire problem. I gave up
  3. #3 Re: Aeroforce says Misfire...
    Jul 2010
    Michigan
    Anyone else have input?? Bill... Bio... :P
    2005 GTP Grey
  4. #4 Re: Aeroforce says Misfire...
    Pennsylvania
    I'm not surprised to see a healthy 3800 misfiring only at idle. If it's misfiring elsewhere, I'd be worried.
  5. #5 Re: Aeroforce says Misfire...
    Quote Originally Posted by SlowNA06 View Post
    I lol'd
  6. #6 Re: Aeroforce says Misfire...
    Pennsylvania
    Okay. Healthy-ish. Whatever.
  7. #7 Re: Aeroforce says Misfire...
    i have one at cold idle when it eats coolant on #6.
    goes away once it revs/warms up.
    Have you tried a case learn?
  8. #8 Re: Aeroforce says Misfire...
    mine always had random misfires at idle. never really did it anywhere else.
  9. #9 Re: Aeroforce says Misfire...
    Jul 2010
    Michigan
    Well that is why the misfire while under light load concerns me. Im assuming that when im coasting I shouldnt be concerned from what you say.
    2005 GTP Grey
  10. #10 Re: Aeroforce says Misfire...
    MA
    cover your bases. change your plugs and wires. swap around coils to see if the "misfire" follws one coil, replace if need be.
    SMGPFC Member #9
  11. #11 Re: Aeroforce says Misfire...
    Jul 2010
    Michigan
    Well Ive seen the misfire on all cylinders so far. So if it is coils it would be all of them. My guess is this would not happen all at once?
    2005 GTP Grey
  12. #12 Re: Aeroforce says Misfire...
    I have a huge idle issue...not sure why.
  13. #13 Re: Aeroforce says Misfire...
    MA
    yeah youre right, forgot its on multiples
    SMGPFC Member #9
  14. #14 Re: Aeroforce says Misfire...
    vac leak?
  15. #15 Re: Aeroforce says Misfire...
    Jul 2010
    Michigan
    Well most likely Ill do the plugs and wires before it gets nice out. Hopefully in the next couple weeks and ill just keep an eye on the aeroforce if it starts going crazy then Ill worry I guess
    2005 GTP Grey
  16. #16 Re: Aeroforce says Misfire...
    Jan 1970
    Maquoketa, Iowa
    3800's are notorious for idle misfires, especially when we go to a colder plug and smaller gap. The most often time a car will misfire is when it is wet/damp out and first starts up. If your going to replace the wires/plugs, put dielectric grease on the coil pack point and the plug.
  17. #17 Re: Aeroforce says Misfire...
    Houston
    I have a cylinder 5 misfire at idle only.
  1. Cylinder #1 misfire and random cylinder misfire
    By whodat79 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-21-2010, 07:16 AM
  2. aeroforce
    By TheOtherNick in forum Off Topic Discussion
    Last Post: 02-04-2009, 08:30 PM
  3. Aeroforce?
    By speedemongtp in forum General Tech Discussion
    Last Post: 11-07-2008, 07:30 PM
