Thread: Cleaned the TB, Runs worse?
Results 1 to 11 of 11
  1. #1 Cleaned the TB, Runs worse?
    GT Level Member fri3dchick3n's Avatar
    Alaska
    So I cleaned my TB out a few days ago. I took the whole TB off and cleaned it with Carb/Choke cleaner that was okay to use on the TB. Replace everything and took it for a test run. Ran good but not as good as I thought it would. Scanned the car at Oreillys today and got the code: P0122 Throttle/Pedal position sensor A circuit low input.
    I did have some trouble plugging in one sensor below the MAF, has some yellow plastic on the harness but plugged in all the way. I'm not exactly sure what this means, seems like everytime I try to fix the car, somethings breaks. : \
    Any suggestions or ideas?
    Edit: I raced today too, not really satisfied with it. Unless that car is that beast. http://www.youtube.com/watch?v=AlWA6-g_cqg
    99 GTP: 3.4'' MPS, Overkill PCM, Intake, Catless SD Headers, TransGo Shift Kit, 180º Thermostat, Flipped Dog Bones
  2. #2 Re: Cleaned the TB, Runs worse?
    Donating Users nascartech's Avatar
    Abbotsford, British Columbia, Canada
    saw ur vid u need exhaust mods like a down pipe headers u bend delete something as for the sensor check the conection again make sure there are no broken or cracked wires
    01 GTP is3 cam 130 springs double roller 60lb injectors lq4 maf headers 4000 stall lowered
    sold 97 GTP stock
    Sold 2001 gp gt ssm90 plog dp 3.8 208 whp 265 at the crank 14.8 1/4
  3. #3 Re: Cleaned the TB, Runs worse?
    Alaska
    Yea, I'm going to work on my exhaust next. I'm just doing some minor maintanence but keep on running into problems hehe. This summer I plan to drop to a 3.4 atleast. I will check the wire again, but which one is it exactly? Was I right about it having a yellow harness?
  4. #4 Re: Cleaned the TB, Runs worse?
    Topeka, KS
    unplug your MAF and see if it runs better you coulda killed it. Also check your TPS sensor. Make sure it's plugged in all the way.
  5. #5 Re: Cleaned the TB, Runs worse?
    Alaska
    For some reason I am having trouble finding out where the TPS is. I've tried googling it but no good description. I'll try the MAF trick but it's farely new, I think its good. Any pictures of the TPS in its place?
  6. #6 Re: Cleaned the TB, Runs worse?
    the TPS is the one closest to the throttle blade. it moves with it.
  7. #7 Re: Cleaned the TB, Runs worse?
    Alaska
    Is this it? I'll just try inspect and replug all of them.
    IMG_02811.jpg picture by fri3dchick3n - Photobucket
    Edit: Replugged the wires, took it for a run. Cleared the codes. Feels like it's running a lot better now. Will try scanning it in a few hours to see if it pops up again. Just would like to thank you guys for the tips and help.
  8. #8 Re: Cleaned the TB, Runs worse?
    Quote Originally Posted by fri3dchick3n View Post
    no thats the iac its below that
    sold 97 GTP stock
  9. #9 Re: Cleaned the TB, Runs worse?
    Alaska
    Yea, I see wich one it is now, that wire is really short on my car and is kind of hard to plug in straight. Not sure why it's like that. Hopefully it'll be ok, seems like if I break that then I'll have to replace the whole fat wad wire that has all the sensor wires : \
  10. #10 Re: Cleaned the TB, Runs worse?
    it's because you have an intake on the car. it isn't meant to be that far away from the inlet of the throttle body.
    i can send you an IAT extension for like $5. have it left over from my car.
  11. #11 Re: Cleaned the TB, Runs worse?
    Alaska
    The IAT wire is just fine, just the TPS has the short wires.
  1. Car starts and stalls worse with throttle
    By gprixster in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-21-2009, 05:44 PM
  2. Can electric superchargers get any worse.....YES THEY CAN
    By 98GT3800 in forum Off Topic Discussion
    Last Post: 06-29-2009, 06:39 PM
  3. Window rattle worse
    By WhiteDevil in forum 04+ Specifics
    Last Post: 04-20-2009, 04:41 PM
  4. Heat/fans problem getting worse
    By Freebeer187 in forum General Tech Discussion
    Last Post: 01-11-2009, 06:38 PM
  5. Things Just Keep Getting Worse *Electrical Problem*
    By GTPJay305 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-04-2008, 12:17 AM
