Thread: Creaky noises...
Results 1 to 10 of 10
  1. #1 Creaky noises...
    Wichita
    Ok so I'm hearing creaky noises from under the hood when I turn the steering wheel. I'm thinking CV joints but im not 100% sure. Nothing vibrates or shakes when im driving so I assume one or both cv joints bad. The creaky noise it all I get
  2. #2 Re: Creaky noises...
    Wichita
    I meant to ask if anyone has any ideas what the problem could be lmk. And thx.
  3. #3 Re: Creaky noises...
    St. Louis
    Sounds like it could be your strut mounts. Mine do that from time to time.
  4. #4 Re: Creaky noises...
    Wichita
    Strut mounts creak when u turn the wheel? Well I suppose, the car is ageing.
  5. #5 Re: Creaky noises...
    St. Louis
    Throw a jack under it and get both front tires off the ground. Fire it up and then turn the wheel lock to lock and see if you hear the squeak. Might also help if someone does it for you while you have yourself down under the car to try and pinpoint the sound.
  6. #6 Re: Creaky noises...
    Wichita
    Hey good idea ill try that.
  7. #7 Re: Creaky noises...
    GT Level Member sportred04's Avatar
    Feb 2010
    indianapolis
    although it might not do it if theres no weight on it. ball joints?
    Quote Originally Posted by Warbeaver View Post
    I loved it when Bill Cosby said, " if you don't want white folks to look at you different, pull your damn pants up and learn to dress yourself"
  8. #8 Re: Creaky noises...
    St. Louis
    This is true, but then you have at least narrowed it down some. Right now it could be the rack, a ball joint (or 2), strut mount, etc...
  9. #9 Re: Creaky noises...
    Wichita
    Im gonna try some wd40 on the ball joints and see if that helps.
  10. #10 Re: Creaky noises...
    Poppin 'em thangs mechguy's Avatar
    Dec 2010
    Canada
    I was thinking the intermediate steering shaft is a possibility.
  1. noises...
    By mousemonster1232 in forum General Tech Discussion
    Last Post: 01-23-2011, 04:14 PM
  2. Rattling noises
    By Ramond in forum Introductions/Noob Questions
    Last Post: 09-19-2010, 12:47 PM
  3. Front end noises
    By kayza in forum General Tech Discussion
    Last Post: 05-31-2010, 08:35 AM
  4. Random Sub noises
    By stoner17971 in forum Audio, Security & Visual Electronics
    Last Post: 07-07-2009, 04:56 AM
  5. K&N Air Intake noises
    By zofsharick@gmail.com in forum General Tech Discussion
    Last Post: 10-19-2008, 09:07 PM
