Thread: Mystery Wire/Hose?
Results 1 to 20 of 27
  1. #1 Re: Mystery Wire/Hose?
    GT Level Member fri3dchick3n's Avatar
    Alaska
    Yup, sucks great! : \
    99 GTP: 3.4'' MPS, Overkill PCM, Intake, Catless SD Headers, TransGo Shift Kit, 180º Thermostat, Flipped Dog Bones
  2. #2 Re: Mystery Wire/Hose?
    Houston
    then thats a vac leak. seal that thing off, or get a new hose to run to your htr core.
  3. #3 Re: Mystery Wire/Hose?
    Alaska
    Alright, I will seal it up and and order a new one. So its called a heater core vacuum hose?
  4. #4 Re: Mystery Wire/Hose?
    Houston
    Im really not sure what its called. Someone asked me where it went the other day. They said they usually see the middle of the vacuum manifold capped, theyve never actually seen a hose come off it. So I traced it down and took those pics. But I do know that if that thing is sucking air, you're loosing powah. I'll have to do some research to see what its function is.
  5. #5 Re: Mystery Wire/Hose?
    Alaska
    Sounds good, and I would really like to know the "function" of this hose. Thanks!
    Edit: It's sealed off good to last for now. Going to buy some brake cleaner and start testing some for more leaks while im at it. Two leaks at once so far..
  6. #6 Re: Mystery Wire/Hose?
    Houston
    Ok, apparently that line controls the switching of your airflow. I.E. Floor, Vent, Defrost. Have you noticed bad air flow, low heat or the controls not switching properly? I know in mine, when I switch to say, front defrost....I hear a little pssshhhh sound.
  7. #7 Re: Mystery Wire/Hose?
    Alaska
    Yea, barely any air flow on full blast. And when I switch to to front top vents, or to bottom feet, It just blows everywhere evenly. Doesnt switch anywhere I want it to.
  1. Mystery Vac line!!
    By Pittman06 in forum General Tech Discussion
    Last Post: 12-22-2009, 08:18 PM
  2. Mystery Plug and Harness Swap Q's
    By tylerbinski in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-23-2009, 07:30 PM
  3. Mystery problem with S/C
    By Freebeer187 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-23-2009, 01:08 AM
  4. Power steering pump mystery
    By cidknee in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-21-2009, 09:50 PM
  5. Mystery Problem, Stalling And More !!
    By 02BlueGT in forum General Tech Discussion
    Last Post: 03-25-2008, 03:53 PM
