Thread: Mystery Wire/Hose?
Results 1 to 20 of 27
  1. #1 Re: Mystery Wire/Hose?
    Houston
    it goes into the cabin and plugs in to the heater core under the dash, behind the center console. It should look like the first pic I posted
  2. #2 Re: Mystery Wire/Hose?
    GT Level Member fri3dchick3n's Avatar
    Alaska
    Yea, alright I found that and it looks exactly like your picture, I tried to see how much of the hose is broken but i can't find anything. Just where it starts and where it ends. What exactly is this hose? And how bad is it that its broken like this?
    99 GTP: 3.4'' MPS, Overkill PCM, Intake, Catless SD Headers, TransGo Shift Kit, 180º Thermostat, Flipped Dog Bones
  3. #3 Re: Mystery Wire/Hose?
    Houston
    not sure...but if that connection at the vacuum manifold isnt capped, its gonna create one hell of a vac leak
  4. #4 Re: Mystery Wire/Hose?
    Alaska
    That vac hose has been like that for as long as I can remember. 3-4 years lol. Im trying to think what to do with it.. stop by the dealership and have them order me a new hose..
  5. #5 Re: Mystery Wire/Hose?
    Houston
    really? Is there just a hose hanging off of that middle connection on the vac manifold? Or is it capped of somewhere? Has your car been runnin like crap?
  6. #6 Re: Mystery Wire/Hose?
    Alaska
    That one picture you sent me to look at the top circle. That hose goes around back, around my coolant, next to the fuse box and it stops. gone.. the car has been running good before I got the vac leak on my throttle body - EVAP hose.(that hose is on its way atm)
  1. Mystery Vac line!!
    By Pittman06 in forum General Tech Discussion
    Last Post: 12-22-2009, 08:18 PM
  2. Mystery Plug and Harness Swap Q's
    By tylerbinski in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-23-2009, 07:30 PM
  3. Mystery problem with S/C
    By Freebeer187 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-23-2009, 01:08 AM
  4. Power steering pump mystery
    By cidknee in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-21-2009, 09:50 PM
  5. Mystery Problem, Stalling And More !!
    By 02BlueGT in forum General Tech Discussion
    Last Post: 03-25-2008, 03:53 PM
