Thread: mass air sensor bad?
Results 1 to 8 of 8
  1. #1 mass air sensor bad?
    Donating Users Regalgs98's Avatar
    Aug 2008
    hamilton,oh
    bought a 98 GTP for cheap throwing the PO102 and PO171. i found a few post with people throwing both and some said PO171 sometimes is a side effect. also found some saying if you unplug the MAF it should do something....
    So i unplugged mine. Before i unplugged it, the car would stumble from time to time and after some driving it would die while driving or at idle. but car would run for 99.99% of the time. After i drove it probably a total of 15-20 minutes and my only noticable problem is a hesitation in throttle response from a stop, sometimes while slowing down and speeding up. didn't sputter or anything i could notice.
    does this mean my MAF is bad???
  2. #2 Re: mass air sensor bad?
    Omaha, NE
    If it has close to the same problem plugged in as it does when it's not then yes, its most likely a maf issue. Have you tried cleaning it?
  3. #3 Re: mass air sensor bad?
    SLP, GTP or call it MUT! thunder71173's Avatar
    West Frankfort Illinois
    I have one if you need it
  4. #4 Re: mass air sensor bad?
    Aug 2008
    hamilton,oh
    yeah its definately bad. drove car probably 20 miles without the maf and it didnt even hiccup.
  5. #5 Re: mass air sensor bad?
    Wichita
    ^^^Oh my business that is a bad maf!
  6. #6 Re: mass air sensor bad?
    Aug 2008
    hamilton,oh
    yeah. definately was. i cleaned first thing. got used to it from having a wrx with a K&N filter.
  7. #7 Re: mass air sensor bad?
    Ohio
    when mine went bad it was terrible as hell. the car just kept stalling out at idle and going down the road.
  8. #8 Re: mass air sensor bad?
    Aug 2008
    hamilton,oh
    Quote Originally Posted by 99PGPGT View Post
    yeah thats what i was trying to say. it sucked.
  1. mass air flow sensor?
    By Bakerdd in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-27-2012, 10:35 AM
  2. Need help-Mass Air Flow Sensor '99
    By msh227 in forum General Tech Discussion
    Last Post: 03-09-2012, 11:54 PM
  3. Which of the following is the MASS AIR FLOW sensor that I need on my 98 GTP?
    By vanels in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-22-2010, 10:22 AM
  4. Mass Air Flow Sensor
    Last Post: 10-19-2010, 11:39 AM
  5. Mass air flow sensor
    By duane9586 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-03-2008, 01:36 PM
