As the title says. I started having a strange knock which after going in with a stethoscope, leads back to the flywheel area. The knock is very consistent but only happens at idle and stops around 1500 RPM
If the hood is closed, You can clearly hear the knock significantly more from the Passenger side front wheel well than you can from the Driver's side front wheel well.
http://www.youtube.c...h?v=h8kBhiEqCmQ
http://www.youtube.c...h?v=paahM-y-IHY
I did a cyl balance test today also.
YouTube - Knocking (3) -- Cylinder balance test.
