Thread: Need help with knock that started shortly after header install.
Results 1 to 4 of 4
  1. #1 Need help with knock that started shortly after header install.
    Out West
    As the title says. I started having a strange knock which after going in with a stethoscope, leads back to the flywheel area. The knock is very consistent but only happens at idle and stops around 1500 RPM
    If the hood is closed, You can clearly hear the knock significantly more from the Passenger side front wheel well than you can from the Driver's side front wheel well.
    http://www.youtube.c...h?v=h8kBhiEqCmQ
    http://www.youtube.c...h?v=paahM-y-IHY
    I did a cyl balance test today also.
    YouTube - Knocking (3) -- Cylinder balance test.
  2. #2 Re: Need help with knock that started shortly after header install.
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    Sounds like a busted flex plate. Also only one of your links work
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  3. #3 Re: Need help with knock that started shortly after header install.
    Out West
  4. #4 Re: Need help with knock that started shortly after header install.
    Out West
  1. header install ?'s
    By taman86 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-05-2011, 12:16 AM
  2. started my sub install.. shot some pics
    By OmegaRed in forum Audio, Security & Visual Electronics
    Last Post: 01-14-2011, 09:08 AM
  3. SD Header Install Soon...
    By theshznt69 in forum 04+ Specifics
    Last Post: 05-23-2010, 05:28 PM
  4. started SSAC install today...
    By benblank in forum 04+ Specifics
    Last Post: 04-17-2010, 07:57 PM
  5. S&S Header Install
    By GRANDPRIXFOOL01 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-23-2009, 09:57 PM
