Thread: Broken bolt.
Results 1 to 9 of 9
  1. #1 Broken bolt.
    GT Level Member fri3dchick3n's Avatar
    Alaska
    I was taking off the body support brace and I ended up breaking the last one, instead of unscrewing it, I was twisting the bolt. Its sticking out about half an inch, Which I think might help to get out but I'm not quite sure how, pliars aren't cutting it lol. I tried uploading a picture but I can't. Stupid uploader doens't work for me. Any ideas on how to take it out?
    99 GTP: 3.4'' MPS, Overkill PCM, Intake, Catless SD Headers, TransGo Shift Kit, 180º Thermostat, Flipped Dog Bones
  2. #2 Re: Broken bolt.
    if you have a grinder with a thin blade you can cut a slot in the bolt thats sticking out and use a flat head screw driver to remove it, if its still not moving use a propane torch and warm up around the bolt, not the bolt but the material around it, to help it expand. good luck, I've been there and it sucks when a bolt breaks off. at least you got something to work with.
  3. #3 Re: Broken bolt.
    St. Louis
    Try soaking it down with PB Blaster and then giving it the slot idea. I usually use a Dremel tool to make the slot. If that doesn't do it then time for the heat wrench!
  4. #4 Re: Broken bolt.
    Alaska
    Cool, I will try that now One more question about the intake air temperature sensor, I've tried to pull it out but its nice and snug, I dont want to break it. Is there a special way for that little thing?
    And I've broke 2 flatheads so far, working on my 3rd atm : \
  5. #5 Re: Broken bolt.
    the air temp sensor just unplug it and rock it back and forth, and pull on it, it will come out.
    if that bolt is still stuck soak it down over night with some penetrating oil, heat it up and try again, or you will have to drill it out.
  6. #6 Re: Broken bolt.
  7. #7 Re: Broken bolt.
    Alaska
    I ended up breaking more tools trying to take it off. I don't think its going anywhere without proper tools. I used a sawzall(?) to cut a slot, then the fatest flathead I could find and then turn it with a pipe wrench and didn't even budge. I'll go see if I can find a cheap bolt remover kit. Thanks for the info.
  8. #8 Re: Broken bolt.
    Charles City, IA
    Drill it out and tap it.
    SMGPFC Two Nipple General
  9. #9 Re: Broken bolt.
    Nov 2010
    Marine City MI
    I just bought this kit works like a champ
    99 GTP, ZZP MPS 2.9 pulley, GenIII supercharger ported & polished, machined intake W/ stage 2 intercooler, XP Cam,ZZP fuel rails, 42.5 injectors, Wizard CAI, custom headers, 3 inch downpipe, into dynomax muffler,180 stat, Northstar TB, 85mm MAF, ZZP trans, 3.29 gears, input shaft and torque converter, stock heads W/Ls6 springs.
  1. Car broken into help please
    By jteske88 in forum General Tech Discussion
    Last Post: 03-10-2011, 02:13 PM
  2. bolt broke off mount brackets to block,where can i find new bolt
    By crystalterry89 in forum General Tech Discussion
    Last Post: 10-21-2010, 06:28 PM
  3. broken cam!
    By ks02sscamaro in forum 3.1L V6 (LHO/LG8)
    Last Post: 09-16-2010, 06:18 PM
  4. Broken Thermostate Bolt & small coolant leak ?!?!?
    By FlaminWhite97GTP in forum General Tech Discussion
    Last Post: 02-15-2010, 07:32 PM
  5. Broken exaust manifold bolt
    By 99prixgt in forum General Tech Discussion
    Last Post: 01-18-2009, 03:14 PM
