Thread: boost gauge problems
Results 1 to 20 of 35
  1. #1 Re: boost gauge problems
    Houston
    Right around here......
  2. #2 Re: boost gauge problems
    GTX Level Member asite57's Avatar
    Oct 2011
    Michigan
    do you pull the vacumn line out of the MAP sensor or do you pull one of the lines off the T thats under the s/c snout
    SOLD. 99 GTP - Open Cone, ZZP STB ,GMPP Front & Rear Sway Bar, 3" DP & Cat-Back, Built Trans, 12'' Brakes, Tune
    http://www.grandprixforums.net/gtp-t...ack-67489.html
    04 SRT4 - Bone Stock....For Now
  1. Why is my boost gauge only reading vacuum and no boost?
    By gtp02 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-21-2010, 02:26 PM
  2. dic boost gauge only shows half boost
    By SilvaMan61 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-10-2010, 07:40 PM
