Thread: Rebuild or used motor
Results 1 to 20 of 26
Threaded View
  1. #13 Re: Rebuild or used motor
    GT Level Member RegalGS98s's Avatar
    NJ
    I wouldn't say 4 feet, but you do need a long extension made up about 2 feet. I use a 17mm 1/2 inch drive deep impact socket and 2 each of 4 1/4 inch and 9 1/4 inch half inch drive impact extensions with my impact gun. Breaks loose like a wheel nut with this setup. You can get it done with a 3/8 drive extension as my friend did one time, but it takes patience cause of the deflection.
    When reassembling, just use the deep socket with the extensions to get it threaded in by hand. Then attach your impact or ratchet to tighten it down. Idiot I bought one of my cars from must of decided the engine and transmission were stuck together when he removed all the visible bolts holding them together cause the engine casing is broke off at this location. He must of used alot of force.
    Good Luck
    SMGPFC #0330 - 3.25, Intercooled, Custom Tune, 1.84rr, LS6 Springs, roller timing chain, SLP Headers, Borla Exhaust, built Trans, B&M Trans Cooler, home cut poly uppers, gapless rings, N* TB, Ported heads.
    Soontocome: CAM?, Custom modified M112, home poured Poly Engine and Trans mounts
  1. m90 rebuild
    By 91z in forum General Tech Discussion
    Last Post: 09-02-2010, 05:58 PM
  2. Rebuild it?
    By Marks97GTP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-17-2010, 07:22 AM
  3. The motor Mount on the passenger side of the motor.
    By Nuzzget in forum 3.1L V6 (LHO/LG8)
    Last Post: 07-30-2009, 09:27 PM
  4. should i rebuild a stock motor?
    By chrisb in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-30-2009, 11:30 AM
  5. Motor & Trans Rebuild Questions
    By BlackGhost in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-11-2008, 10:16 AM
