Thread: having trouble finding misfire
Results 1 to 20 of 25
  1. #1 Re: having trouble finding misfire
    GT Level Member Spartanzz's Avatar
    Dec 2010
    Lawrenceville, GA
    We tried that and no it doesn't. And I'm now pretty sure it can't be anything to do with spark and one big problem with it is its not constant enough to throw a code just a pending one unless I let it idle for a long time. But u can feel the misfire or at least a rough sound every now and then while at a light and like I said its not constant. We have now replaced the icm coil to 6 and 3 and all plugs only thing would be the word but it doesn't move when I switch them... and some goes for injectors
    p.s. my friend just told me it could be the MAF. whats yalls opinion on that? i figured if it was the maf the misfire would be alot worse.
  2. #2 Re: having trouble finding misfire
    Fla.
    You can tap on the Maf, and the engine will sputter if it's bad. I'd check the compression in no.3 against 1 or 5 since their easy to get at. Low compression will show it's head at low rpms..
  3. #3 Re: having trouble finding misfire
    Fla.
    You can tap on the Maf, and the engine will sputter if it's bad. I'd check the compression in no.3 against 1 or 5 since their easy to get at. Low compression will show it's head at low rpms.. Maybe a broken insulator on the plug also, and you can't see it.
  1. Cylinder 5 misfire trouble code P0305
    By michellebuck76 in forum General Tech Discussion
    Last Post: 04-11-2013, 06:02 PM
  2. trouble finding a new laptop
    By KwazrollinZ28GTP in forum Off Topic Discussion
    Last Post: 01-30-2011, 06:31 PM
  3. help finding something
    By DDPeppa in forum Visual/Body Modifications
    Last Post: 04-09-2009, 06:55 PM
  4. Finding +and- on a cap
    By WhiteGT in forum Audio, Security & Visual Electronics
    Last Post: 12-22-2008, 03:52 PM
  5. trouble starting, misfire
    By Toasty in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-16-2008, 11:55 PM
