Thread: having trouble finding misfire
Page 2 of 2 FirstFirst 12
Results 21 to 25 of 25
  1. #21 Re: having trouble finding misfire
    GT Level Member Spartanzz's Avatar
    Dec 2010
    Lawrenceville, GA
    yes i do have the APP104 plugs in there because i was hoping to start getting more mods on to get a pully soon but money is tight now. The other thing is it had the misfire on the old plugs i pulled out which were stock from what i remember. And the 104's i have in there are gapped at .055. So i wouldnt think it was the plugs but i may be wrong and probably later tonight i will try to unplug the maf and see if it changes.
  2. #22 Re: having trouble finding misfire
    Dec 2010
    Lawrenceville, GA
    ok guys im at a loss the MAf looks new and is working fine. The wires look to be giving good spark to the plugs. Just got a few more questions...1. is there any possibility a clogged cat can cause a misfire only at idle? 2. if the misfire is mechanical basically burnt valve or something along those line wouldn't you be hearing something else other than just the misfire an wouldn't it be a constant misfire? any wild and crazy ideas as to how i find where the misfire is coming from?
  3. #23 Re: having trouble finding misfire
    SE Level Member Shang TI's Avatar
    Austin TX
    Do what bluegtp91 said find somewhere to get or rent a bore scope and check out the cylinder, said lady could have been lying stock lims are plastic on these cars and do go out. How many miles are on the car?
  4. #24 Re: having trouble finding misfire
    Dec 2010
    Lawrenceville, GA
    yeah ill be going to a friends house and he may have one so hopefully i can get this misfire gone soon cuz now its holding me back from getting an emissions on the car and it tagged properly...
  5. #25 Re: having trouble finding misfire
    SE Level Member fst4dr's Avatar
    Calgary
    well I would recomend a compression test and a cyclinder leak down test from these two tests we can determine a few other things
    1998 4dr GTP Bright Red
    180* Stat/FWI/ZZP PCM/SD Headers/MPS 3.4/104's/6000k H.I.D/Tinted tails/Eibach's/GMPP STB/12'' Brake upgrade/18'' Ruff Black/Machined
  1. Cylinder 5 misfire trouble code P0305
    By michellebuck76 in forum General Tech Discussion
    Last Post: 04-11-2013, 06:02 PM
  2. trouble finding a new laptop
    By KwazrollinZ28GTP in forum Off Topic Discussion
    Last Post: 01-30-2011, 06:31 PM
  3. help finding something
    By DDPeppa in forum Visual/Body Modifications
    Last Post: 04-09-2009, 06:55 PM
  4. Finding +and- on a cap
    By WhiteGT in forum Audio, Security & Visual Electronics
    Last Post: 12-22-2008, 03:52 PM
  5. trouble starting, misfire
    By Toasty in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-16-2008, 11:55 PM
