Thread: Headers installed, stuttering issues now
Results 1 to 17 of 17
  1. #1 Re: Headers installed, stuttering issues now
    GT Level Member 99GPGTP's Avatar
    Rome GA
    when i installed my sd headers i coverd my a** and removed my plugs so that i didnt break them.
    im will billboost37, a huge vac leak will cause it. but it sounds to me like u may have cracked a few plugs also. you did extend the rear o2 sensor correct????
    99gtp 3.4"on ported m90, zzp 1.0 pcm, speeddaddy headers, stock mufflers w/cat and res delete,104's,FWI,180* stat, exhaust ported heads,Dog bones flipped, 18" 350z wheels
  2. #2 Re: Headers installed, stuttering issues now
    MA
    sounds like a vac leak. i'd listen to Mr.Boost
    SMGPFC Member #9
  3. #3 Re: Headers installed, stuttering issues now
    Plug your maf back in and please do your wallet a favor, stop trying to diagnose stuff that you didn't touch. This is something you touched/broke. You know you have a vacuum leak, it acts like a vacuum leak, it smells like a vacuum leak.... I'm gonna say...most likely ..it's a vacuum leak. Unplugging the maf put you on the table which runs rich etc. That's way it seemed a little better for a bit.
    Chris..next time you want to free rev past 4K punch yourself in the nuts. The only good that'll come from that is learning how to swap a motor. I'm thinking you don't want to do that.
  4. #4 Re: Headers installed, stuttering issues now
    SE Level Member tu8i1o7's Avatar
    Siuox Falls, SD
    Thanks to everyone, I got it fixed today. Went and picked up the evap solenoid and some new plugs just in case. put the solenoid on, still ran crappy. So on to the plugs, where under further inspection there was a hairline crack on 2 plugs (looks like you and I are the same starscream haha).
    I really need to be thanking you bill, you sure know your stuff. I might just have to buy you a beverage or two if you ever make it down to NC haha. I usually don't throw my wallet at the problem. But with a newborn and working long hours. It didn't leave much time to troubleshoot. I'm not at all new to the 3800, ive had a 99 since i was 16, and now my 2005. Been in mechanics for a while too. Im a helicopter mechanic in the Marines, so you know I deffinately mess some stuff up LOL. But once again thanks everyone and sorry for sounding n00bish.
  5. #5 Re: Headers installed, stuttering issues now
    Chris...we've all done it.. That's why I was a little harsh.. you needed to refocus.
    Am I the only guy that always pulls plugs to put headers in? We don't have a lot of room....why not give yourself as much as possible?
  1. SD Headers installed and A+++++
    By DCVING in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-07-2010, 06:56 PM
  2. Installed plog (and DP) and now issues! (w/vid)
    By SliceTheRice in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-05-2010, 07:03 PM
  3. Speed daddy headers installed.
    By EricGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-29-2010, 03:45 PM
  4. headers installed
    By boostedcompg in forum General Tech Discussion
    Last Post: 12-19-2009, 03:24 AM
  5. ZZP Headers installed!
    By Reptile in forum General Tech Discussion
    Last Post: 03-10-2009, 11:11 AM
