Thread: 3.6" Pulley
Results 1 to 20 of 37
  1. #1 3.6" Pulley
    GT Level Member TheAce144's Avatar
    Dec 2010
    Montreal, Canada
    Hey guys, I have a 04 Grand Prix GTP with the following mods :
    1)ZZP 180* Thermostat
    2)NGK Spark Plugs and Wires
    3)Cold Air Intake
    4)Overkill PCM
    5)Resonator delete and muffler delete
    I wanted to know if I could drop a pulley size and go with a 3,6" pulley...Or would it be better with some more supporting mods like headers or 1.9 rockers...
    I know that if I install headers I will lose low end torque...will the pulley swap bring it back to normal?
    My car is a daily driver, looking for some more torque while keeping an eye on budget.
    Thanks for your time!
    04 GTP CompG: SSAC Headers, 3.6" Modular Pulley System, Autolite 104, NGK Spark Plug Wires, CAI, ZZP 180 T-Stat, Overkill PCM (Custom Street Tuning By Will), Goodyear Eagle F1 Tires, Hawk HPS Brake Pads, Magnaflow Magnapacks 4", SE Front Fascia
    Check Out My Car! ---
  2. #2 Re: 3.6" Pulley
    Florida
    only real mod you have is the Intake.
    Get a set of headers, and some Copper plugs, and then drop to a 3.6"
    Just browse through this, it'll tell you everything you need to know
    http://www.grandprixforums.net/safel...car-17482.html
    Just remember the Gen V doesn't need as small a pulley as the gen 3.
  3. #3 Re: 3.6" Pulley
    Portland Oregon
    I had headers, intake, and a tune when I dropped to a 3.6 and I still had a few degrees of kr
  4. #4 Re: 3.6" Pulley
    Vancouver, WA
    Quote Originally Posted by OH4CompG View Post
    Same here. I had to drop timing in some spots to 15* to kill it all.
    Slowest 'Cooled Gen V ever
  5. #5 Re: 3.6" Pulley
    Florida
    Yeah, you're better off saving the engine, and getting more flow mods first, then dropping pulley sizes...that's just common sense.
  6. #6 Re: 3.6" Pulley
    Donating Users nascartech's Avatar
    Abbotsford, British Columbia, Canada
    get some headers and a good tune and 104s then 3.6 and have it scanned
    01 GTP is3 cam 130 springs double roller 60lb injectors lq4 maf headers 4000 stall lowered
    sold 97 GTP stock
    Sold 2001 gp gt ssm90 plog dp 3.8 208 whp 265 at the crank 14.8 1/4
  7. #7 Re: 3.6" Pulley
    Leave the stock pulley and throw 20* of timing at it after you get headers.
    It'll be faster than the 3.6" cars with stock timing most likely.
  8. #8 Re: 3.6" Pulley
    Feb 2009
    flintnasty MI
    My car is really fast with the stock pulley IMO...
    Headers are not going to "make you lose low end torque". Blowers eliminate the need for advanced scavenging or whatever you get from a crappy log manifold system.
  9. #9 Re: 3.6" Pulley
    People think they lose low end from installing headers, its just moving the powerband higher guys.
  10. #10 Re: 3.6" Pulley
    Dec 2010
    Montreal, Canada
    Found this image, GTO with and without headers, interesting indeed
  11. #11 Re: 3.6" Pulley
    Dec 2010
    Montreal, Canada
    I see the powerband is moving, but how does it affect driveability, torque wise (throttle response, ect)...?
  12. #12 Re: 3.6" Pulley
    It's more linear...and your not getting that crazy torquey feeling with headers and a stock pulley...but you get that back when you crank up the timing or pulley down for more boost. Also...its about flow...these cars tend to run great around 10-12psi.
  13. #13 Re: 3.6" Pulley
    Dec 2010
    Montreal, Canada
    Just checked their site today and the SSAC headers are now 175$, massive price drop!!! Are they any good, because most people seem to go with the Speed Daddy headers.
  14. #14 Re: 3.6" Pulley
    They're the same.
    SSAC just recently updated their price.
  15. #15 Re: 3.6" Pulley
    Never Never Land
    dont the ssac tend ot have better reviews though?
  16. #16 Re: 3.6" Pulley
    Donating Users
    South Deerfield, MA
    SSAC and Speed Daddy headers are the same thing. Not similar products with a similar design, but the same product. I have seen both of them. They are both supplied by the same place and sold by two different companies.
    2002 GTP: GMPP Sway Bars, BMR trailing arms, KYB AGX/Vogtlands, 12" brake upgrade
    Modified SSAC headers, K&N Intake, 3.4 MPS, S1X, Gen V, 104's, HPTuned.
  17. #17 Re: 3.6" Pulley
    true story. SSAC just have a nameplate saying what they are.
  18. #18 Re: 3.6" Pulley
    And the SD's still have the plate...just no tramp stamp.
  19. #19 Re: 3.6" Pulley
    KSteelwheelzJ klj5022's Avatar
    New Carrollton,MD
    So what would a 3.6 do to a 01 GTP then?
    I just wish the police loved my car as much as i do 3.5,160 Stat,HAI,ZZP F/R STB, SSAC Headers, Reptile PCM
  20. #20 Re: 3.6" Pulley
    Quote Originally Posted by klj5022 View Post
    Give you a tad more boost?
  1. Supporting mods for 3.4" - 3.2" Pulley
    By Clar2478 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-26-2008, 12:33 PM
