Thread: Revs go up/not changing gears?
Results 1 to 19 of 19
  1. #1 Revs go up/not changing gears?
    SE Level Member SUGAR's Avatar
    Dec 2010
    Canada
    Cannot figure this out. Took it to the dealership + another place. Both said that they don't know whats wrong because no codes are showing!
    O.k here is the problem. Automatic '99 GTP
    This doesn't happen all the time, but sometimes while accelerating the revs go up, but doesn't change gears. When this happens the engine, and sometimes the battery, and oil light come on. Then the steering gets stiff at this point the car is still on, but basically dead while continuing to move forward. After pulling over I turn off the car, wait a couple seconds. Start it up, and fires fine and everythings normal. But sometimes it will struggle to start, but always drives away normal. What is going on here?
  2. #2 Re: Revs go up/not changing gears?
    Houston
    Sounds similar to a Crankshaft position sensor failure.
  3. #3 Re: Revs go up/not changing gears?
    Does it make any noises?
    Oil Light coming on doesn't sound good to me. Also...CPS like stated ^^ will cause your tach to bounce while driving...
  4. #4 Re: Revs go up/not changing gears?
    I'm going to third a crank sensor as the car is stalling. The revs are a little odd, but likely a bad reading from the sensor.
  5. #5 Re: Revs go up/not changing gears?
    Dec 2010
    Canada
    Doesn't make any noises.
  6. #6 Re: Revs go up/not changing gears?
    Right..that's because it's not running. No noises are good noises.
  7. #7 Re: Revs go up/not changing gears?
    Dec 2010
    Canada
    Could it be anything else?
    Any other input?
  8. #8 Re: Revs go up/not changing gears?
    Kansas
    major vac leak?
    SOLD 1999 GT Silvermist TS
  9. #9 Re: Revs go up/not changing gears?
    Quote Originally Posted by SUGAR View Post
    sure it could be say ignition switch, driver error (if you turned the key off etc)
    Most likely..it's a crank sensor. Very easy and cheap to replace.
  10. #10 Re: Revs go up/not changing gears?
    Dec 2010
    Canada
    O.k thanks guys, I'll look into it.
  11. #11 Re: Revs go up/not changing gears?
    Dec 2010
    Canada
    Finally got the Crank sensor, going to install it now. Where is it located, and do I need to do move anything, or take anything out to swap it?
    Thanks '99 Auto, GTP
  12. #12 Re: Revs go up/not changing gears?
    GT Level Member fri3dchick3n's Avatar
    Alaska
    I had that revving problem when my tranny was going out ^^
    99 GTP: 3.4'' MPS, Overkill PCM, Intake, Catless SD Headers, TransGo Shift Kit, 180º Thermostat, Flipped Dog Bones
  13. #13 Re: Revs go up/not changing gears?
    Minnesota
    I would think it was the pressure control solenoid in the transmission before the crank sensor.
    But:
    Disconnect the battery-
    Take the belts off-
    Remove 2 screws (1) securing the coil (2) to the ignition control module-
    Remove the right front wheel and tire-
    Remove the right inner fender access cover-
    Remove the crankshaft harmonic balancer-
    Remove the crankshaft position sensor shield (1) (Do not use a pry bar)-
    Disconnect the sensor electrical connector-
  14. #14 Re: Revs go up/not changing gears?
    Dec 2010
    Canada
    I'll keep that in mind guys. Does anyone know where the crankshaft position sensor is on the car though?
  15. #15 Re: Revs go up/not changing gears?
    Minnesota
    ^^^^^^^^^^^That is how you do it. If you have never taken the harmonic balancer off and you don't have a impact, I would try to find someone who has one.
  16. #16 Re: Revs go up/not changing gears?
    Dec 2010
    Canada
    Ok thanks, do I need a harmonic pulley or anything like that?
  17. #17 Re: Revs go up/not changing gears?
    St. Louis
    Yes, you need a harmonic balancer remover/reinstaller. Should be able to get one at Autozone as a loaner.
  18. #18 Re: Revs go up/not changing gears?
    Dec 2010
    Canada
    Thank YOU!!!
  19. #19 Re: Revs go up/not changing gears?
    Minnesota
    That work? Crank sensor?
  1. trans revs out
    By kbmukdk2316 in forum Pre-1996 4 speed Automatic (4T60E)(4T60E-HD)
    Last Post: 11-01-2010, 02:50 PM
  2. High Revs, Late Shifting, and low HP
    By Wigsos in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-30-2010, 09:24 AM
  3. engine revs when putting into gear
    By breeze12 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-07-2009, 09:28 AM
  4. 2000 GTP - gears 3 & 4 gone
    By JCI400 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-07-2009, 10:04 AM
  5. Gears jumping around?
    By WhiteGT in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-18-2008, 09:10 PM
