Thread: GTP wont stay running longer than a couple seconds...
Results 1 to 3 of 3
  1. #1 GTP wont stay running longer than a couple seconds...
    GTP Level Member Smokin2000gtp's Avatar
    Jul 2008
    Dekalb, IL
    Well my GTP wont stay running longer than a couple seconds now. On friday my car starting acting up, it started misfiring and dieing on me one night and then wouldnt start but started up fine in the morning after jumping it. The car drove fine for the rest of the day but then come night time, the car started acting up and left me stranded again. But again it started right up in the morning and again drove fine the rest of the day till night time... Now it wont stay running even thawed out in a garage...
    I tried unplugging the MAF but no luck (LQ4 MAF btw). Fuel pump has 12 volts to it KOEO. I bought a new FPR and when I went to bleed the schrader valve no fuel came out. After replacing the FPR and a cracked vacuum fitting the car did stay running longer, like 10 seconds versus about 2 before. The pump is a brand new racetronix fuel pump, I replaced it myself like a week and a half ago and my car ran great, until friday when it started acting up (P0300 misfire, and HO2 sensor high voltage). The spark plugs are new too.
    Any thoughts?? Does this sound like a bad fuel filter? Cause I cant get my old one off..
    2000 Silvermist Grand Prix GTP Coupe
    Mods-Custom Thrasher CAI|Ceramic Coated S&S Headers|3.4" pulley|ZZP S4 Blower|Powrtuner|PRJ 10.4mm wires|HIDs|F-Body brakes|Koni's and Voglant's|
  2. #2 Re: GTP wont stay running longer than a couple seconds...
    Sounds a lot like a bad fuel pump resistor. Off to find the info on that for ya
    Here ya go
    http://www.grandprixforums.net/fixin...lem-26549.html
  3. #3 Re: GTP wont stay running longer than a couple seconds...
    Jul 2008
    Dekalb, IL
    Well my fuel pump resistor went out like 2 years ago, so I did the fuel pump bypass trick and I've been driving with it like that ever since. Could the fuel pump speed relay be bad now?
  1. Car wont stay running
    By Robinson B in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-12-2011, 05:39 PM
  2. wont stay running
    By DarkCherry in forum General Tech Discussion
    Last Post: 09-24-2010, 11:06 PM
  3. need help car wont stay running
    By ALACEY in forum Introductions/Noob Questions
    Last Post: 07-03-2010, 11:58 PM
  4. Car wont stay running *HELP!!!
    By silverPGP in forum General Tech Discussion
    Last Post: 06-06-2010, 02:46 PM
  5. car wont stay running
    By 98gpgtp in forum General Tech Discussion
    Last Post: 04-17-2010, 07:41 AM
