Thread: Car wont stay running
Results 1 to 6 of 6
  1. #1 Car wont stay running
    Nov 2009
    lancaster wi
    Hey guys I have a 99 GTP and it wont stay rinning. I Thought it was a fuel problem so I replaced the filter, pump, and pressre regulator and its still doing the same thing. If i start it it will run for about 3 sec. then dies but starts right back up. If I start it and give it gas i i can get it to run on the rev limiter but as soon as I ease off it dies. Any help will be very much assreciated Thanks
  2. #2 Re: Car wont stay running
    Bonaire 31005
    Its the fuel pump resistor. 100% positive. here is a temp. fix for the problem. Look under the hood inside of the fuse box and you should see this....
    http://www.scacgp.com/mods/fuel_fix/relays.jpg
    Take the relay out that is indicated in the picture. Bend the tab that is indicated as shown in the pics. Bend it break it whatever. Your car will start right up. eventually it would be a good idea to buy a fuel pump resistor and have it installed.
  3. #3 Re: Car wont stay running
    GTX Level Member cerick08GP's Avatar
    x2 on the resistor
    Ten years of continuous driving excitement and counting!
    2008GP
    ||HV3 insert||PowerSlot rotors w/Hawks||LED interior||MSD 8.5mm
    2002GP||sold
  4. #4 Re: Car wont stay running
    Nov 2009
    lancaster wi
    oh wow thanks so much the took care if the problem. I really wish I would have asked you guys before I spent About 500 in parts that cant be taken back. Thankd very much again
  5. #5 Re: Car wont stay running
    Bonaire 31005
    No problem. Glad you got it fixed.
  6. #6 Re: Car wont stay running
    Jan 2009
    Williamsport
    I was having this same problem for over a week, we replaced the fuel pump, fuel filter, crank position sensor, and a slew of other random things. Can't believe this little bugger was the problem. Thank you so much!
  1. wont stay running
    By DarkCherry in forum General Tech Discussion
    Last Post: 09-24-2010, 11:06 PM
  2. 2000 gtp wont stay running after start??
    By handymontana in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-14-2010, 06:42 AM
  3. need help car wont stay running
    By ALACEY in forum Introductions/Noob Questions
    Last Post: 07-03-2010, 11:58 PM
  4. Car wont stay running *HELP!!!
    By silverPGP in forum General Tech Discussion
    Last Post: 06-06-2010, 02:46 PM
  5. car wont stay running
    By 98gpgtp in forum General Tech Discussion
    Last Post: 04-17-2010, 07:41 AM
