Thread: Exhaust Help
Results 1 to 20 of 26
  1. #1 Exhaust Help
    I am looking into getting a downpipe from ZZP and I was just wondering what i all need to get for a downpipe. I have a 2000 GTP and I do not want to do any welding to it. I am looking at getting the 2.5 inch 304 bolt in with cat. That and the gaskets should be all I need correct?
    How effective is the DP?
  2. #2 Re: Exhaust Help
    or could I go with the DP without the cat and a Rear O2 Emulator?
  3. #3 Re: Exhaust Help
    TDCRacing
    Guest
    If your city doesent have emissions (mine doesent) then go with the 2.5 ss bolt in off road dp...and yes the 02 imulator is nessary to not have a cel light...if not you will have a cel light but it wont hurt performance in any way.
  4. #4 Re: Exhaust Help
    Moore, Oklahoma
    I'd go with a 3" DP w/ no cat if you have no emissions. You can eliminate the codes one of 3 ways... Get a rear o2 sim, get an overkill pcm and requested the rear O2 to be deleted, or get a tuner and delete it yourself.
    You can buy bolt in DPs which would be 3" DP, back down to 2.5" to bolt on to your stock cat-back if thats what your running.
    You may check out Hogan performance and WBS, you maybe able to get a better deal on DPs...
    Shawn W. Larsen
  5. #5 Re: Exhaust Help
    TDCRacing
    Guest
    Quote Originally Posted by Iron Indian View Post
    Just my opinion....with stock exhaust dont get a 3''..I dont see the point in a 3in dp on stock 2.5 in exhaust...if you plan on upgrading the stock exh at some time go for it...but it is only like 10 bucks more for the 3in i belive...so who cares....
  6. #6 Re: Exhaust Help
    Moore, Oklahoma
    3" DP has proven its gain over the years on these cars. Besides, the farther back exhaust goes, the least it needs the bigger diameter. If I remember correctly, out of even stock manifold its 3" or close to it.
    I'd say spend the $10, get the 3". You ain't gonna loose any power, you may not gain much either. I've had about 10 different setups on my car so I can speak for damn near anything. I currently have a full 3" Exh, 2.25 Y it ain't hurtin me, ask my tires...
    Shawn W. Larsen
  7. #7 Re: Exhaust Help
    TDCRacing
    Guest
    yea i was mainly talking about the difference in hp between a 3 and a 2.5
  8. #8 Re: Exhaust Help
    I really do not plan on doing any other exhaust mods to it so I may just go with the 2.5. If I go with the 3, will everything still bolt up?
    We do not have emissions inspections where I live. Will not having the cat hurt anything? (Mileage or otherwise) Will my car be louder without the cat?
    Thanks guys.
  9. #9 Re: Exhaust Help
    TTT
  10. #10 Re: Exhaust Help
    May 2008
    McHenry IL
    i am interested in this thread and will be watching to figure out some issues like deleteing my cat "I HAVE NO EMISSIONS ALSO" anyways i want to get a good roaring sound exhaust without killng my bank. Its completely stock. So this DP and sensor and info i will be looking for so good topic TCO
  11. #11 Re: Exhaust Help
    TDCRacing
    Guest
    yes the 3'' dp will still bolt up...as long as you get the bolt in version.it is reduced to 2.5 to bolt up to the stock mani and the stock catback.Shouldnt hurt miliage.cat is for emissions only.The car is slightly louder with a dp and no cat...i couldnt even notice except at lower rpm's...even with full headers i could not tell any difference.I plan on keeping the muflers stock because i dont like the sound a v6 with exhaust gives off
    Quote Originally Posted by TCO View Post
    Thanks guys.
  12. #12 Re: Exhaust Help
    GT Level Member johnnyj773's Avatar
    May 2008
    Chicago(southside)
    so which dp should i go with on a 00 gp gt with slp exhaust?2.5 or 3? and we have emmisions.and want to get rid of u bend.
    Wizaired cai,taylor 8mm wires,ngk tr55 plugs, msd coils.slp power flo exhaust w/gtx tips. future mods:zzp 1.0 pcm,slp headers, zzp hv3 uim runners ,zzp hv tb,gmpp sway bars,kyb agx struts,18"A.R.M:Rogues wrapped in firestone firehawk gt's.that's all performance wise.
  13. #13 Re: Exhaust Help
    I am going to bring this topic back up. I think I am going to order the 2.5 inch bolt in offroad. I haven't decided if I want the 304 stainless or not. Is it really worth the extra $50?
    Also, I plan on getting this and then sending in my stock DP and getting the $50 coupon. With that I am going to buy the O2 Emulator. Will I be fine running my car without this for a couple weeks until I get it?
  14. #14 Re: Exhaust Help
    TDCRacing
    Guest
    yep. the bank 1 sensor one (right on the rear header) is the only o2 that has anything to do with fueling. the other sensor is only there to tell you if your cat is working or not. so the only thing the o2 emulator is going to do is turn the ses light off. If your planning on keeping that setup for a while and want the resale value to stay up there in case you do want to sell it i'd get the stainless. When i bought the 2.5 bolt in offroad i got mine in stainless.
  15. #15 Re: Exhaust Help
    Well I really don't plan on selling the DP once its on the car because I won't have a stock one to replace it with.
  16. #16 Re: Exhaust Help
    SE Level Member hotshot's Avatar
    R.I.
    Check with local scrapyards before you send the pipe back. the cat should be worth about a hundred bucks because of the platnum in them. I saw they were offering the coupon but I would rather have cash.
    98 GTP - slp powerflo cat back, built tranny, AP104s, homemade FWI and intense 180 stat.
  17. #17 Re: Exhaust Help
    One more question. ZZP has the option of adding a rear O2 bung in the offroad pipe. Could I do this instead of the O2 Emulator or will I still have a SES light?
  18. #18 Re: Exhaust Help
    May 2008
    McHenry IL
    cant u just take the blub outta the dash?
  19. #19 Re: Exhaust Help
    I'm sure I could but then when I actually have something wrong I won't know because I won't have a SES light.
  20. #20 Re: Exhaust Help
    Barksdale AFB, LA
    The after market cat may or may not set a CEL. Some guys go for months with no light, and some only make it a week. Some never see it. It really seems to depend on the car.
    2009 Subaru Impreza WRX STI
  1. exhaust Q
    Last Post: 06-19-2008, 10:26 PM
  2. exhaust
    By zach_gt in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-22-2008, 11:06 AM
  3. exhaust
    By crshoveride in forum Off Topic Discussion
    Last Post: 03-13-2008, 02:40 PM
  4. Which exhaust?
    By robahr24 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-02-2008, 05:15 AM
