Thread: Gen V Top Swap Felpro Gasket Set
Results 1 to 10 of 10
  1. #1 Gen V Top Swap Felpro Gasket Set
    GTP Level Member Impala131's Avatar
    Knoxville, TN
    http://www.amazon.com/Fel-Pro-HS-9089-PT-4-Gasket/dp/B002E2SVJO/ref=sr_1_1?s=automotive&ie=UTF8&qid=1454935469&veh icle=2007-52-598-39--1-6-5-7406-850-1-1---2-0&sr=1-1&ymm=2007%3Apontiac%3Agrand+prix&keywords=head+ga sket
    Hey all, doing a Gen V top swap on my Impala very soon (L36 bottom end).... this seems like the best bang for the buck to me as gaskets go. Agreed?
    Already got plenty of black RTV for the LIM corners, am I missing any gaskets?
    2003 Grand Prix GTP.... the journey begins again....
    E85 Self Tune with HPT, 80# Injectors, Gen V 3.4 pulley, SD Headers, AL605 Plugs
  2. #2 Re: Gen V Top Swap Felpro Gasket Set
    looks good but id order head bolts too. not sure if others have reused them i wouldnt anyways. maybe some exhaust manifold bolts too exhaust bolts are a pain to reuse.
  3. #3 Re: Gen V Top Swap Felpro Gasket Set
    Knoxville, TN
    Quote Originally Posted by ImNowTylerTibbets View Post
    Definitely getting new head bolts, didn't see a full gasket kit that included them, though. Already have newer exhaust bolts from SD headers.
  4. #4 Re: Gen V Top Swap Felpro Gasket Set
    Kemmerer, Wyoming
    if you are doing a gen 5 swap, you are going to need a gen 5 supercharger gasket, not a gen 3 like that one is.
  5. #5 Re: Gen V Top Swap Felpro Gasket Set
    you can do better then that felpro listing. its got more un needed stuff, and missing a lot of what you do need.
    look up a lower convertion kit, buy head gaskets and lim gaskets a tb and sc gasket and your done. gen 5 you can rtv it on if you like, the metal gasket is like 40 bucks.
    full gaskets, head bolts with oil and coolant ran me right around 200.
  6. #6 Re: Gen V Top Swap Felpro Gasket Set
    Knoxville, TN
    Quote Originally Posted by SgtMarshal View Post
    uuuhhh.... check the listing again? Clearly shows a metal S/C gasket (unless the photo is incorrect), afaik the gen 3 never had a factory metal gasket replacement, only paper.
  7. #7 Re: Gen V Top Swap Felpro Gasket Set
    Knoxville, TN
    Okay, I'll look into piecing together. The Fel-Pro head gaskets seem a lot more common around the auto parts stores, but should I spring for OEM head gasket? I've heard rumors about rumors about sealing issues with the Fel-Pro ones, but no evidence.
    I've always had good luck with the Fel-pro metal LIM gaskets, though.
  8. #8 Re: Gen V Top Swap Felpro Gasket Set
    i got everything from advance auto on line, all but the lim gaskets, i got the magnum kit from ra for 40 shipped. that lim kit comes with more stuff then any other lim kit. they work just fine. look just like the acdelco ones.
  9. #9 Re: Gen V Top Swap Felpro Gasket Set
    i made to orders too, break the parts up so you get the most of the discount codes.
  10. #10 Re: Gen V Top Swap Felpro Gasket Set
    Kemmerer, Wyoming
    Quote Originally Posted by Impala131 View Post
    my fel-pro head gaskets have worked fine with my xp cam, ported heads and until a few months ago a full size intercooler. probably made about 350 hp. I did use head studs, but that shouldn't make much difference for the sealing of the head gaskets.
  1. LIM-FelPro gasket failure?
    By michael redmon in forum 3.1L V6 (LHO/LG8)
    Last Post: 01-10-2015, 05:11 AM
  2. Felpro Head Gasket Question?
    By 99GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-28-2013, 02:02 PM
  3. ZZP's Top Swap Gasket Kit?
    By Speedy1973 in forum General Grand Prix Discussion
    Last Post: 02-08-2013, 10:23 PM
  4. LIM gasket - felpro or GM
    By cavGTP in forum 04+ Specifics
    Last Post: 12-03-2010, 12:30 PM
  5. SC Gasket Swap
    By Darkcelle in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-23-2008, 03:45 PM
