Thread: Engine seized?
Results 1 to 20 of 94
  1. #1 Re: Engine seized?
    SE Level Member fst4dr's Avatar
    Calgary
    yeah just make sure you pull the plugs and check for coolant in the cylinders and if there is that just know that if it was happening for an extended period of time and there was coolant getting in to the oil past the rings or somewhere else than there is a possiblity of the bottom end being toast. but if it was running fine before than there is a good chance that it should be ok. the reason i say this is that typically the engine will run rough and have a miss if it burning coolant so you probably would have noticed that before this occured. but like i said pull those plugs and belt and try spinning it over to try to nail this down for sure.
    off to bed now but will check in to see where this goes and if i can offer my advice. that is if it is welcome!
    1998 4dr GTP Bright Red
    180* Stat/FWI/ZZP PCM/SD Headers/MPS 3.4/104's/6000k H.I.D/Tinted tails/Eibach's/GMPP STB/12'' Brake upgrade/18'' Ruff Black/Machined
  2. #2 Re: Engine seized?
    Not trying to discredit or question things 4dr...but I've yet to see one of these factory HG's go in a few hundred of these engines. They are much more rare than a LIM..
    However.. has this been confirmed to have coolant in the cylinders? It looked like that was suggested and never comfirmed by the OP.
    OP says he has a supercharged car, yet he says "the belt looks good". Uh..there's supposed to be two. Do you see the second belt? I've seen pullies etc go bad and the second belt wrap around the HB etc and cause a near lockup condition due to binding. The smell of rubber and sounds described would be typical of a bad pulley and belt shredding.
    Like I mentioned, no disrepect etc.. Just wondering if we've fully diagnosed the car yet.
  1. 88 Grand Prix: Wiring Harness? Possibly alternator seized?
    By nikiyo88 in forum General Tech Discussion
    Last Post: 01-28-2011, 08:23 PM
  2. How To Open A Seized Door
    By Lakerman in forum General Tech Discussion
    Last Post: 01-26-2011, 09:26 AM
  3. Service Engine light flashes... engine shakes...hardly any power at all
    By bigbluegtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-08-2010, 07:10 PM
  4. Spartans Engine Swap (Engine Damage Pics on Front Page!)
    Last Post: 05-05-2010, 12:50 AM
  5. Engine Seized
    By Green38 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-09-2010, 01:33 AM
