Thread: IC fuel rails?
Page 2 of 2 FirstFirst 12
Results 21 to 30 of 30
  1. #21 Re: IC fuel rails?
    Stock pump is fine...people are running into the 10's with just a pump rewire.
  2. #22 Re: IC fuel rails?
    GT Level Member shawn3091's Avatar
    Jan 2009
    State College PA
    thats what i figured, im thinking i should be in low 13's when ic'd
  3. #23 Re: IC fuel rails?
    SE MI
    the aeromotive rails don't fit.
    If you are running h body / l36 front mount, they won't clear the l36 mount, you'd have to clearance some of the structural webbing and I think it would fail.
    The brackets barely clear the blower flange bosses on the front rail
    The brackets in the rear do not clear the blower flange boss near the alternator, at all. If the rail were to seat completely in the rear, it looks like it would touch the boss, and there would be no way for the map sensor bracket to mount under it.
    a 90* orb fitting near the alternator puts the an outlet basically directly behind the snout, so you'd have to go to a different fitting or something...
    its just a lot of headaches... I'll let you know what I do to get them to work...
  4. #24 Re: IC fuel rails?
    Have any pictures?
  5. #25 Re: IC fuel rails?
    I have the new version of the ZZP logs and love the.
    BTW, ive ran the "cut up stocker" mod for my fuel lines and it looks soooo tacky and i wasn very comfortable running them...
    Ive also had the ones in your original post and they were decent for my budget but I would HIGHLY recommend logs... I lost some knock, no leaks to this day, and they look so much more bad ass than anything else...
  6. #26 Re: IC fuel rails?
    Never Never Land
    Will wbody's stores modded rails clear a stage 2 IC? It says SS but nothing about anything bigger than that.
  7. #27 Re: IC fuel rails?
    Ignore the retarded piping.... that will be redone soon enough.
    Thats a 2.25" core.
  8. #28 Re: IC fuel rails?
    Jersey
    Quote Originally Posted by That Canadian Guy View Post
    Ignore the retarded pulley.... that will be redone soon enough.
    Thats a 2.25" core.
    fixed
    I run zzp modded rails, i don't know if they leak, since i didn't get to install them yet
    16' wrx sti- stock
  9. #29 Re: IC fuel rails?
    Never Never Land
    matt are you running wbody's modded rials?
  10. #30 Re: IC fuel rails?
    yes, and i love my stock pulley.
  1. Custom AN Fuel Line setup for PRJ Fuel Rails... [*]
    By Iron Indian in forum How To Write-Ups/Tech Tips
    Last Post: 01-17-2009, 07:53 PM
  2. Fuel pressure and fuel in the rails
    By 02BlueGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-13-2008, 12:03 AM
  3. Fuel rails
    By David99GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-03-2008, 05:46 PM
